Flash a BD-RE BU40N drive - first time
outland
So, I decided to give it a go and flash my own drive. You can see the drive (which is attached via USB enclosure) on the attached screen shots.
I'm on macOS (M1 chip) but have access to a Windows 10 PC and plan to use this viewtopic.php?f=16&t=22896
I'm totally committed and know I can brick my drive so:
1. Can you guys/girls point me to the correct firmware to flash it with?
2. Anything I should be aware of before I go?
- makemkv.png (184.24 KiB) Viewed 27260 times
- drive-lg.jpg (255.51 KiB) Viewed 27260 times
Re: Flash a BD-RE BU40N drive - first time
Flash the 1.04 from BU40N-Main in the firmware pack.
outland
This one?
New! The all you need firmware pack: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
and this one:
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Will this work with DVDFab, I want to be able to make Iso's
and this one:
Lbento
Flash the 1.04MK with the SDFtool Flasher v1.3.3 and the the 1.00DE to work with DVDFab
outland
So, I should flash it directly from 1.04 to 1.00DE for it to work on both MakeMKV and DVD Fab?
Using this:
DE_LG_BU40N_1.00.bin
Again, thanks!
Using this:
Again, thanks!
Nooutland wrote: Sun Jun 05, 2022 11:42 am So, I should flash it directly from 1.04 to 1.00DE for it to work on both MakeMKV and DVD Fab?
Using this:
Again, thanks!
outland
Again, thanks for the reply.
Also, I understand why people would want to buy a pre-flashed drive. For many reasons not what I want to do. So just asking for best advise before flashing
So, why no?
So, why no?
Please flash first 1.04 or 1.03 MK. Only afterwards flash it again to downgrade to 1.00
outland
So first to this one from mk-firmware-pack-20200720:
HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Then if I want DVDFab:
outland
Got this far and everything looks as it is supposed to but nothing happens when I press "Start"
Any ideas?
Any ideas?
- IMG_20220606_091252.jpg (239.19 KiB) Viewed 27127 times
try closing makemkvoutland wrote: Mon Jun 06, 2022 7:19 am Got this far and everything looks as it is supposed to but nothing happens when I press "Start"
Any ideas?
if still no just use the command line from my guide
outland
Ok, did not do the trick so this command:
makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Again, thanks!
Again, thanks!
outland
...and just run it from Windows PowerShell?
