Posts: 4989 Joined: Wed Nov 22, 2017 11:45 pm
Post
by MartyMcNuts » Sun May 01, 2022 11:15 pm
rayians wrote: Sun May 01, 2022 2:41 pm
Another thing that is strange is I was attempting to go to firmware 1.00MK. I figured once 1.02MK was installed, all I had to do was another flash and it should work. I first tried without checking "ENC", it didn't work. I tried by checking ENC and it still didn't work. I feel like I am missing something here.
With these BP60NB10's with SVC: NB12, to downgrade to 1.00-MK firmware try the below steps.
1. Flash the drive with BP60NB10 1.02-MK.
2. Using the recovery option in SDFtool Flasher, select BP60NB10 1.02-MK as the incorrect firmware in the popup, then in the select firmware box, select BP60NB10 1.00-MK.
rayians
Posts: 13 Joined: Sun Aug 11, 2019 10:25 pm
Post
by rayians » Wed May 04, 2022 8:57 pm
Marty, you are thebomb.com! Thank you so much!!
themoleculoman
Posts: 1 Joined: Sat May 28, 2022 6:59 am
Post
by themoleculoman » Sat May 28, 2022 7:02 am
Thank you so much Marty and other posters for the information. After reading through everything it only took 30 seconds to flash a newly bought WH16NS60 with OWC Pro enclosure
Error code showed up like other users mentioned, but MK1.03 was successfully flashed to MK1.02 and I'm ripping my first 4K UHD
TomKay
Posts: 3 Joined: Wed Jun 01, 2022 2:23 pm
Post
by TomKay » Wed Jun 01, 2022 2:25 pm
Hello everyone,
I got an LG Hitachi - BH16NS55 and wanted to use the SDFtool Flasher (1st post) and the recommended firmware (HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936)
When selecting the device I will get an error window (
https://prnt.sc/-ybXYwerJP6b ) and an error message:
Running on W10 x64 and started it with empty/closed tray and admin rights:
https://prnt.sc/jjgaF2cw32Cs
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
System.Private.CoreLib
Assembly-Version: 6.0.0.0.
Win32-Version: n/v.
CodeBase: .
Assembly-Version: 1.3.3.0.
Win32-Version: n/v.
CodeBase: .
System.Runtime
Win32-Version: n/v.
CodeBase: .
Assembly-Version: 6.0.2.0.
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Drawing.Primitives
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Drawing.Common
Win32-Version: n/v.
CodeBase: .
System.Threading
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Collections
Win32-Version: n/v.
CodeBase: .
System.Diagnostics.Process
Win32-Version: n/v.
CodeBase: .
Microsoft.Win32.Primitives
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Threading.Thread
Win32-Version: n/v.
CodeBase: .
Accessibility
Assembly-Version: 4.0.0.0.
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Numerics.Vectors
Win32-Version: n/v.
CodeBase: .
System.Memory
Win32-Version: n/v.
CodeBase: .
System.ComponentModel
Win32-Version: n/v.
CodeBase: .
System.Resources.Extensions
Win32-Version: n/v.
CodeBase: .
System.Drawing
Win32-Version: n/v.
CodeBase: .
System.ObjectModel
Win32-Version: n/v.
CodeBase: .
System.Linq
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Collections.Concurrent
Win32-Version: n/v.
CodeBase: .
mscorlib
Win32-Version: n/v.
CodeBase: .
Microsoft.Win32.SystemEvents
Win32-Version: n/v.
CodeBase: .
System.Collections.NonGeneric
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Private.Uri
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Xml.ReaderWriter
Win32-Version: n/v.
CodeBase: .
System.Private.Xml
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Net.WebClient
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Xml.XmlSerializer
Win32-Version: n/v.
CodeBase: .
Microsoft.Win32.Registry
Win32-Version: n/v.
CodeBase: .
System.Runtime.CompilerServices.Unsafe
Win32-Version: n/v.
CodeBase: .
System.Runtime.Loader
Win32-Version: n/v.
CodeBase: .
System.Windows.Forms.resources
Win32-Version: n/v.
CodeBase: .
System.Diagnostics.StackTrace
Win32-Version: n/v.
CodeBase: .
System.Reflection.Metadata
Win32-Version: n/v.
CodeBase: .
System.Collections.Immutable
Win32-Version: n/v.
CodeBase: .
************** JIT-Debuggen **************
Any idea on that? Can I just continue flashing or what did I do wrong?
TomKay
Post
by TomKay » Wed Jun 01, 2022 5:25 pm
Nevermind - I used dvdfab's feature to downgrade my drive. it worked
Posts: 4645 Joined: Tue Feb 19, 2019 10:32 pm
Post
by Coopervid » Wed Jun 01, 2022 8:12 pm
TomKay wrote: Wed Jun 01, 2022 5:25 pm
You should have first flashed to BH16NS55 1.0x and only then cross-flash it to BH16NS60. If you spent money for the DVDfab flasher you were too impatient.
Post
by MartyMcNuts » Wed Jun 01, 2022 10:45 pm
TomKay wrote: Wed Jun 01, 2022 2:25 pm
Hello everyone,
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Runtime
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Threading
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Collections
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Accessibility
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Memory
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Drawing
Win32-Version: n/v.
CodeBase: .
System.ObjectModel
Win32-Version: n/v.
CodeBase: .
System.Linq
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
mscorlib
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Private.Uri
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
System.Private.Xml
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
Win32-Version: n/v.
CodeBase: .
It looks like you are using a sata/USB adapter, which is causing the issue. (Notice the drive says Asmedia instead of BH16NS55)
TomKay
Post
by TomKay » Thu Jun 02, 2022 9:02 am
Coopervid wrote: Wed Jun 01, 2022 8:12 pm
Didnt buy it just because of this, had it before already, and just discovered it
papacarter
Posts: 7 Joined: Thu Apr 23, 2020 3:16 am
Post
by papacarter » Mon Jun 20, 2022 7:09 am
I have a ASUS BW-16D1HT connected to my laptop via usb / Sata, please see information about the drive here: (Screenshot 1)
Screenshot 1 screenshot 1 _ makemkv drive info.PNG (24.21 KiB) Viewed 20574 times
I see that the firmware isn't encrypted as per this screenshot obtained via the SDFtool (Screenshot 2)
Screenshot 2 screenshot 2 _ sdftool drive info.PNG (25.78 KiB) Viewed 20574 times
Although I tried flashing the drive using the ASUS flash tool, it was throwing "Updating Failure #5". Will the SDFTool be able to help?
I am keen to knwo how do I proceed?
Thanks in advance.
totofroto
Posts: 1 Joined: Sun Jun 19, 2022 6:43 pm
Post
by totofroto » Mon Jun 20, 2022 3:12 pm
hallo
i am trying to flash my BR Drive, Model BH16NS55 with friendly Firmware,
which firmware for this drive
see the Pic that i have added
for Example i have selected MK version(see Pic)
is this correct, pls help meeee
edit:
as i understood i should do the following:
1- BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
2- WH16NS60 1.02MK > DE_LG_WH16NS60_1.00.bin
is that ok
totofroto on Wed Jun 22, 2022 1:44 pm, edited 2 times in total.
Posts: 6020 Joined: Sun Aug 24, 2014 5:49 am
Post
by Billycar11 » Mon Jun 20, 2022 10:15 pm
papacarter wrote: Mon Jun 20, 2022 7:09 am
I have a ASUS BW-16D1HT connected to my laptop via usb / Sata, please see information about the drive here: (Screenshot 1)screenshot 1 _ makemkv drive info.PNG
Thanks in advance.
It is encrypted use the command line flasher and use enc or download an old version of sdf GUI
It would also be helpful if you read the firmware and send it to Marty he could then add it to the list
papacarter
Post
by papacarter » Tue Jun 21, 2022 5:40 am
Thanks @Billycar11.
Could you please guide how do I use the command line flasher and which firmware version do I use? Apologies if this has been answered before as I am new to all this, what is "enc"?
I also have the read dump of the firmware and happy to send it to Marty.
Thanks in advance.
Post
by MartyMcNuts » Tue Jun 21, 2022 11:25 pm
Thanks in advance.
I'm not aware of any ASUS drives having encrypted firmware. Try flashing it to ASUS BW-16D1HT 3.10-MK using SDFTool flasher. It willl either flash successfully or it will not flash at all.
If the firmware is infact encrypted (I still doubt it) you can easily toggle the encrypted flag in SDFtool flasher by clicking on the red X.
papacarter
Post
by papacarter » Wed Jun 22, 2022 6:11 am
Hi Marty,
Legend ! Thanks for the suggestion and it worked like a charm
Truly appreciated!!
Thank You again
Post
by Billycar11 » Wed Jun 22, 2022 7:02 am
papacarter wrote: Wed Jun 22, 2022 6:11 am
Hi Marty,
Truly appreciated!!
Thank You again
so was it encrypted did you click the x?
