Double Indemnity (Criterion) 4K - Failed to open disc (May 31st Release)
HDMOVIESOURCE
#1 Post by HDMOVIESOURCE » Tue May 31, 2022 8:02 pm
Double Indemnity 4K (Criterion Collection) is out today (May 31st - 2022) and MKV says "Failed to open disc"
I have the Pioneer BDR-XD07UHD 4K drive, and this thing has no issues reading discs, it's great, but this one just cannot read.
THIS IS WHAT HAPPENED
MakeMKV v1.16.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=27184B96DBEE)
Saved AACS dump file as C:\Users\mlg_t/.MakeMKV/MKB20_v76_DOUBLE_INDEMNITY_B818.tgz
Does anybody know what the issue is? Are they using a more advanced security method?
Any feedback is welcome.
Carl.
Re: Double Indemnity (Criterion) 4K - Failed to open disc (May 31st Release)
#2 Post by Woodstock » Tue May 31, 2022 9:46 pm
Today is May 31st. The disk came out today. So, it isn't on the list yet.
If you've sent the file in, it should be extractable within a few days, though.
HDMOVIESOURCE
#3 Post by HDMOVIESOURCE » Wed Jun 01, 2022 4:28 am
Who do I send the files to?
#4 Post by Woodstock » Wed Jun 01, 2022 12:35 pm
You want to send C:\Users\mlg_t/.MakeMKV/MKB20_v76_DOUBLE_INDEMNITY_B818.tgz to svq@makemkv.com for processing.
HDMOVIESOURCE
#5 Post by HDMOVIESOURCE » Thu Jun 02, 2022 5:27 pm
Woodstock wrote: Wed Jun 01, 2022 12:35 pm You want to send C:\Users\mlg_t/.MakeMKV/MKB20_v76_DOUBLE_INDEMNITY_B818.tgz to svq@makemkv.com for processing.
Okay, thank you.
HDMOVIESOURCE
#6 Post by HDMOVIESOURCE » Fri Jun 03, 2022 3:37 pm
Is there a way to check when these titles are added? Is there a link to a nightly build or a weekly build for MakeMKV that adds new titles like? Or is there new builds going up all of the time? Thanks.
#7 Post by Woodstock » Fri Jun 03, 2022 4:27 pm
Cannot say - have not tried any 4K disks recently. And it only checks to see if there is a key when you ask MakeMKV to decode a 4K disk.
What will definitely happen (assuming you have automatic downloads enabled) is that, once the system is updated, MakeMKV will download the key from the server. If it hasn't downloaded it yet, it hasn't been updated yet.
HDMOVIESOURCE
#8 Post by HDMOVIESOURCE » Sat Jun 04, 2022 12:03 pm
Woodstock wrote: Fri Jun 03, 2022 4:27 pm Cannot say - have not tried any 4K disks recently. And it only checks to see if there is a key when you ask MakeMKV to decode a 4K disk.
Oh I see, so as long as that's enabled I don't have to download a new version or anything right?
Dan-O
#9 Post by Dan-O » Mon Jul 18, 2022 9:41 pm
FYI, there may be multiple versions of this disc. I tried to read my copy using MakeMKV, and it gives me the same error as the OP. Only difference is my AACS dump file has a different name.
OP:
mine:
MKB20_v76_DOUBLE_INDEMNITY_EE83.tgz
Of course, I sent my tgz file in, so hopefully it gets added soon.
Nocobo
#10 Post by Nocobo » Tue Jul 09, 2024 5:54 pm
If anyone is also running into this problem there seems to be a third version of this disc:
OP:
Dan-O:
Mine:
MKB20_v76_DOUBLE_INDEMNITY_F117.tgz
I just submitted the dump.
