Unable to download latest sdf file
eldiosyeldiablo
Post by eldiosyeldiablo »
It appears that the file is trying to be downloaded from [https://makemkv.com/sdf.bin](https://makemkv.com/sdf.bin) but it is actually at [https://www.makemkv.com/sdf.bin](https://www.makemkv.com/sdf.bin) now.
MakeMKV v1.16.7 win(x64-release) started
Downloading latest SDF to C:\\Users\\ME/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
I did manually download the sdf.bin file and placed it in c:\\users\\ME\\.makemkv but I still cannot successfully open any blueray nor any ultra disks. DVD disks are fine.
Has anyone encountered this issue?
Any suggestions or ideas on how to fix?
Re: Unable to download latest sdf file
Post by d00zah »
Can you please copy/paste Drive Information / LibreDrive Information from the MakeMKV Info pane?
sdf.bin download (largely) only necessary for latest UHD keys.
IF you are unable to read BD/UHD (BLUE laser), but DVD/CD (RED laser) is OK. the associated laser MAY have gone bad. Let's see what you're working with.
roldogg
Post by roldogg »
I'm having the same issue (Automatic SDF downloading is disabled or failed)
OS device name: G:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIKYFHACB1541
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Firmware version: 1.02
I just tried again, only because it's been a while, and now I'm receiving a different message:
Downloading latest SDF to C:\Users\micha/.MakeMKV ...
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Evaluation version, 15 day(s) out of 30 remaining
Downloading latest HK to C:\Users\micha/.MakeMKV ...
Saved AACS dump file as C:\Users\micha/.MakeMKV/MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_F2B7.tgz
Post by d00zah »
Better.
Suggested reading: UHD FAQ
eldiosyeldiablo
Thank you d00zah,
Current profile: DVD-ROM
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: M00LC4D3543
Highest AACS version: 61
Post by d00zah »
Welcome to the party. :)
eldiosyeldiablo
d00zah, patched 1.02 version can read DVDs but not blueray nor uhd.
I repatched to 1.03 and Windows can see the bluray.
MakeMKV can also now see the bluray. Right now I have it doing a backup to my hard disk unencyrpted.
Any ideas why patched 1.02 cannot see the disks but the manufacturer patch 1.03 can?
Post by d00zah »
eldiosyeldiablo wrote:
Mon May 30, 2022 2:02 am
Not sure I understand this statement. The drive info you posted reports "Product: BD-RE WH16NS60, Revision: 1.02" & the log clearly shows MakeMKV could "read" the UHD disc well enough to generate a dump file.
Are you, perhaps, confusing the ability to "decrypt" w/ the ability to "read"? The "patched 1.02" FW IS the recommended version for MakeMKV.
"WH16NS60 on any Firmware directly to > WH16NS60 1.02MK"
eldiosyeldiablo
You may have read roldogg post earlier in my thread and got them mixed up. His post had the dump. I did not have any dumps.
With 1.02 patch version MKV UI says it could read them but actual Blu-ray and uhd disks could not be read at all. Neither Windows 10 nor MakeMKV would see those disks when inserted.
When I went back to the manufacture's 1.03 firmware version both windows 10 and makemkv could read the Blu-ray disk. Last night's backup of a Blu-ray disk was successful using 1.03 firmware.
This verifies that the lasers in the disk drive are fine. That was your hypothesis earlier and I wanted to check that and return the drive if needed.
I will attempt to re-patch to version 1.02 using SDFtool Flasher (v1.3.3) later today and retest.
Thank you,
-D
Last edited by eldiosyeldiablo on Mon May 30, 2022 4:47 pm, edited 1 time in total.
Post by d00zah »
Mon May 30, 2022 4:22 pm
Indeed I did. Sorry. Initially, I was looking for more info, as you didn't provide much to go on. Didn't catch the 'me, too' poster change.
The 'no BD/UHD, but DVD OK' scenario CAN Indicate a defective drive, but sometimes just a power cycle is sufficient to set things right.
When requesting assistance, it's helpful to provide as much up-front detail (drive info, logs) as possible so we don't need to resort to speculation (or fortune telling :) ).
eldiosyeldiablo
Thank you and sorry about that. I thought all of my problems were stemming from not being able to download that file as it appears the URL has changed.
I will patch after a backup of a UHD disk is done and also perform a full power down. I do not recall if I did a full power cycle earlier.
Post by d00zah »
All that said, I still don't know what drive I'm speculating about. If LibreDrive Information indicates LD is enabled AND you are successfully reading/ripping discs, no need to further muck about.
