did i brick my drive? buffalo
pupster
#1 Post by pupster » Mon May 23, 2022 9:01 pm
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d F: rawflash enc -i \t\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file \t\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: BUFFALO_Optical_Drive_BU13_212009251100_MOFL7EA3249
100% Operation finished
Program Flash NG 06/29/00
Command produced error code 0x8f062900
now the drive isn't recognized by windows and the tray isn't opening....
Re: did i brick my drive? bullalo
#2 Post by Billycar11 » Tue May 24, 2022 12:59 am
likely not unplug the drive for a min plug it back in choose recovery in sdftool gui choose the wrong firmware then the right follow the steps and wait for it to be done is it should come back to life if you let it sit long with the wrong firmware you could have burned the laser out.
pupster
#3 Post by pupster » Tue May 24, 2022 4:26 am
thanks...
well...i tried to load sdftool flasher and it's giving this "Unhandled exception has occurred in your application." when i select my drive:
when i try to select the wrong firmware (or the right firmware), the recover drive option is greyed out. i didn't use sdftool the first time when i flashed the wrong firmware as it was giving the same/similar error before...
what i ignore the initial error i sdftool and try to write the correct firmware (i can't recover as it's greyed out), i get "command produced error code 0x8f05c103" and sdftool stops
Error log from sdftool when i try to select my bricked drive...:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.3.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.CompilerServices.Unsafe
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
System.Threading.ThreadPool
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
#4 Post by MartyMcNuts » Tue May 24, 2022 5:23 am
pupster wrote: Tue May 24, 2022 4:26 am thanks...
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Accessibility
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
You need to be running a recent version of Windows 10 64 bit and have MakeMKV (v1.15.3 or above) installed in the default directory to ue SDFtool Flasher.
pupster
Re: did i brick my drive? buffalo
#5 Post by pupster » Sat May 28, 2022 12:03 am
well i tried putting the new replacement drive on a windows 10 x64 machine and i got the same error; unhandled exception using sdftool (latest) and latest make mkv installed.
ideas?
can i still flash using the command line tool, or do i risk bricking my drive again? i think i used the wrong firmware to flash the first time around....
it's a buffalo "BU13" is the firmware version... BRUHD-PU3-BK
#6 Post by MartyMcNuts » Sat May 28, 2022 12:38 am
pupster wrote: Sat May 28, 2022 12:03 am well i tried putting the new replacement drive on a windows 10 x64 machine and i got the same error; unhandled exception using sdftool (latest) and latest make mkv installed.
ideas?
Did you try running it as an administrator??
You should be able to use the command line tool. The firmware really depends on what you want to end up on and what ripping software you use.
In any scenario, you want to flash BU40N 1.03-MK first. You could leave the drive on this firmware if you like. If you want to use a different firmware, from here you could flash to:
  • Buffalo BU12-MK
  • BU40N 1.00
BU40N 1.03-MK and BU12-MK work with MakeMKV (and should work with AnyDVDHD beta version).
BU40N 1.00 works with the above plus other software such as DVDFab etc..
pupster
#7 Post by pupster » Sat May 28, 2022 2:10 am
yup running as admin; tried to upload video but it won't let me attach
so i'm not seeing the 1.03 mk in the all firmware packet...so you're saying i DONT want to do this?
since that's the 1.02 firmware......
i see THIS post and a file linked in the first post. is that file the correct 1.03 MK?
viewtopic.php?f=19&t=19422
it doesn't say it's 1.03 mk just 1.03nm...:
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.zip
(1.27 MiB) Downloaded 1927 times
download/file.php?id=1937
#8 Post by MartyMcNuts » Sat May 28, 2022 2:57 am
pupster wrote: Sat May 28, 2022 2:10 am yup running as admin; tried to upload video but it won't let me attach
HELL NO!!!!!! HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin is desktop firmware for a desktop drive. NEVER, EVER flash desktop firmware to a slim drive.
pupster wrote: Sat May 28, 2022 2:10 am i see THIS post and a file linked in the first post. is that file the correct 1.03 MK?
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 is the correct firmware. We all say MK as it's far easier than NM0000......
pupster
#9 Post by pupster » Sat May 28, 2022 5:16 am
right i actually meant to say...
makemkvcon64.exe f --all-yes -d F: rawflash enc -i \t\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
that would be the CORRECT way to manually flash from the command prompt since sdftool is giving me errors?
#10 Post by Billycar11 » Sat May 28, 2022 5:19 am
pupster wrote: Sat May 28, 2022 5:16 am right i actually meant to say...
read the guide or get my or martys automated flasher
pupster
#11 Post by pupster » Sat May 28, 2022 5:56 am
i read the guide up to the point where i realized i effed up (copied the wrong firmware) and i watched the video; i just can't get the sdftool to open the buffalo drive on my systems. from looking at the forums it seems there may be a problem flashing it w/in the default enclosure. anyone know if i for sure have to remove it and put it in another enclosure like the vantec NST-510S3-BK that does support usb flashing?
i think marty's automated flasher IS the sdftool, isn't it? that's what not working... [got from this link: viewtopic.php?f=16&t=22896]
I'm using SDFtool 1.3.3 and it says NET framework 4.7.2 is already installed; i'm using windows 10
in the enclosed video, even though it looks like the drive flashed, when i load it up in makemkv, it still shows it's on the same BU13 platform...and encrypted
pupster
#12 Post by pupster » Sat May 28, 2022 6:13 am
figured it out...the checkbox for the encrypted option wasn't showing (see video) - dunno why the font is not letting me see it, but clicking on the word encrypted allowed me to see part of a green check mark, and after that was ticked it worked...thanks all
pupster
#13 Post by pupster » Sat May 28, 2022 6:47 am
MartyMcNuts wrote: Sat May 28, 2022 12:38 am
  • Buffalo BU12-MK
  • BU40N 1.00
Thanks again sir. I did downgrade to BU40N 1.00. Seems like there's no reason to install BU12-MK (even though this is a "Buffalo drive" since that has less capability vs. the stock BU40N 1.00?
#14 Post by MartyMcNuts » Sat May 28, 2022 10:50 am
pupster wrote: Sat May 28, 2022 6:47 am
  • Buffalo BU12-MK
  • BU40N 1.00
Less software compatibility, yes.
