quietvoid
Post by quietvoid » Fri May 27, 2022 11:38 am
RESET_9999 wrote: Fri May 27, 2022 11:03 am still doesnt make sense.
The file is the original one unless the bd rip I downloaded got messed up. I dont see how it would cause a luma difference like that and IIRC, the PQ image were identical.
And even stranger, how can it just affect the Shield. And no we did not encode "something" else in resolve.
Of course it makes sense. The input was probably color managed in Resolve, making it tone map.
The metadata shows it: 1000 nits mastering, DCI-P3.
So the Shield apparently doesn't do well with tone mapping from 10k nits + BT.2020 in YCbCr, even with Dolby Vision.
The files only look similar with all planes combined. See single planes: https://slow.pics/c/ZoxjvanI
So what likely happened is that Resolve converted from 10k nits BT.2020 to 1000 nits DCI-P3.
NiCE77 wrote: Fri May 27, 2022 5:43 am @quietvoid
Someone replied on the Firecore forum about Apple TV RPU management:
Yeah, I know. Eventually I'll make a CM v4.x only file.
Post by RESET_9999 » Fri May 27, 2022 12:01 pm
quietvoid wrote: Fri May 27, 2022 11:38 am So what likely happened is that Resolve converted from 10k nits BT.2020 to 1000 nits DCI-P3.
no, the Resolve encoded file is still 10 000nits.
As for the color management in resolve, you might be right.
Post by RESET_9999 » Fri May 27, 2022 1:46 pm
NiCE77 wrote: Fri May 27, 2022 5:43 am Someone replied on the Firecore forum about Apple TV RPU management:
"Apple devices always ignore L2 trim in profile 8.4 video. Actually there are two version of Apple’s profile 8.4, the early version is L1 only and old OS (like ios14) doesn’t handle trims at all (except profile 5). The recent version uses newer algorithm which needs L8 trim."
https://community.firecore.com/t/dolby- ... /19713/302
so do you see an L1 response with the 8.4 sample ?
realbabilu
Post by realbabilu » Fri May 27, 2022 1:56 pm
Video
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 1 h 50 min
Bit rate                                 : 17.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.090
Stream size                              : 13.8 GiB (96%)
Writing library                          : x265 3.4hy:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=1 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=96 / keyint=96 / gop-lookahead=0 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=18000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=24500 / vbv-bufsize=24500 / vbv-init=0.6 / vbv-end=0.6 / vbv-end-fr-adj=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=825,118 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / no-concatenation / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Encoded date                             : UTC 2022-05-27 13:38:54
Tagged date                              : UTC 2022-05-27 13:38:54
Maximum Content Light Level              : 825 cd/m2
Maximum Frame-Average Light Level        : 118 cd/m2
Codec configuration box                  : hvcC
Drag and drop your MKV file and press enter...E:\mov\tor\Mortal.Kombat.2021.2160p.mkv
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped) and/or press enter...n
Measuring the HDR10 video letterbox...
min: 0.0001 cd/m2, max: 1000 cd/m2
Maxcll: 825
Maxfall: 118
LAV Splitter Source not found.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Parsing madVR measurement file...
Error: The system cannot find the file specified. (os error 2)
any clue with HDR10 inject auto?
deadchip12
Post by deadchip12 » Fri May 27, 2022 1:57 pm
@RESET_9999
I have a question regarding the x700: some mkv dolby vision movie files or mkv sdr movie files have dolby atmos dd+ 5.1 and the bluray player refuses to play the audio track. Using tsmuxer to convert those mkv files to .ts seems to solve the problem. Is that the right way to do it? Any drawbacks to picture or sound quality?
Post by RESET_9999 » Fri May 27, 2022 2:46 pm
realbabilu wrote: Fri May 27, 2022 1:56 pm any clue with HDR10 inject auto?
Just tried that bluray remux and no issue, so there might be something going on with your encode.
1) Workflow.1= INJECT + AUTO-L5 + INJECT DV
2) Workflow.2= INJECT + MANUAL-L5 + INJECT DV
3) Workflow.3= INJECT + MANUAL-L5 + INJECT DV + TrueHD_to_TrueHD.ac3 + DDP_1536kbps
4) Workflow.4= INJECT + MANUAL-L5 + INJECT DV + TrueHD_to_TrueHD.ac3
5) Workflow.5= INJECT + MANUAL-L5 + INJECT DV + DDP_1536kbps
6) Workflow.6= Back to main menu
Choice? [1,2,3,4,5,6]?1
--input must be HDR10 MKV
--This workflow will measure HDR10, generate RPU, auto edit L5 and inject
--The black bars detection may not be perfectly accurate. It's maybe better to measure them manually
Drag and drop your MKV file and press enter...S:\Mortal.Kombat.2021.HDR.mkv
Maxcll: 825
Maxfall: 118
Measuring video file "S:\Mortal.Kombat.2021.HDR.mkv" using D3D11 (native)...
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 825, MaxFALL: 118 nits
Measurements:
  Frames: 158329, MaxCLL 100%: 1117, 99.9%: 994, MaxFALL: 562, AvgFALL: 11, AvgFMLL: 307 nits
Progress: 100%
Generating metadata...
Generated metadata for 158329 frames
Done.
EditConfig {
    mode: 0,
    convert_to_cmv4: false,
    remove_mapping: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 276,
                        bottom: 276,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Editing active area offsets...
Final metadata length: 158329
Writing RPU file...
Parsing RPU file...
Processing input video for frame order info...
Warning: Input file already has RPUs, they will be replaced.
Computing frame indices..
Rewriting file with interleaved RPU NALs..
Parsing RPU file...
  "dovi_profile": 8,
  "header": {
    "rpu_nal_prefix": 25,
    "rpu_type": 2,
    "rpu_format": 18,
    "vdr_rpu_profile": 1,
    "vdr_rpu_level": 0,
    "vdr_seq_info_present_flag": true,
    "chroma_resampling_explicit_filter_flag": false,
    "coefficient_data_type": 0,
    "coefficient_log2_denom": 23,
    "vdr_rpu_normalized_idc": 1,
    "bl_video_full_range_flag": false,
    "bl_bit_depth_minus8": 2,
    "el_bit_depth_minus8": 2,
    "vdr_bit_depth_minus_8": 4,
    "spatial_resampling_filter_flag": false,
    "reserved_zero_3bits": 0,
    "el_spatial_resampling_filter_flag": false,
    "disable_residual_flag": true,
    "vdr_dm_metadata_present_flag": true,
    "use_prev_vdr_rpu_flag": false,
    "prev_vdr_rpu_id": 0,
    "vdr_rpu_id": 0,
    "mapping_color_space": 0,
    "mapping_chroma_format_idc": 0,
    "num_pivots_minus_2": [
      0,
      0,
      0
    "pred_pivot_value": [
        0,
        1023
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "nlq_pred_pivot_value": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "rpu_data_mapping": {
    "mapping_idc": [
        0
        0
        0
    "mapping_param_pred_flag": [
        false
        false
        false
    "num_mapping_param_predictors": [
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
    "poly_order_minus1": [
        0
        0
        0
    "linear_interp_flag": [
        false
        false
        false
    "pred_linear_interp_value_int": [
    "pred_linear_interp_value": [
    "poly_coef_int": [
          0,
          1
          0,
          1
          0,
          1
    "poly_coef": [
          0,
          0
          0,
          0
          0,
          0
    "mmr_order_minus1": [
    "mmr_constant_int": [
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
  "vdr_dm_data": {
    "compressed": false,
    "affected_dm_metadata_id": 0,
    "current_dm_metadata_id": 0,
    "scene_refresh_flag": 0,
    "ycc_to_rgb_coef0": 9574,
    "ycc_to_rgb_coef1": 0,
    "ycc_to_rgb_coef2": 13802,
    "ycc_to_rgb_coef3": 9574,
    "ycc_to_rgb_coef4": -1540,
    "ycc_to_rgb_coef5": -5348,
    "ycc_to_rgb_coef6": 9574,
    "ycc_to_rgb_coef7": 17610,
    "ycc_to_rgb_coef8": 0,
    "ycc_to_rgb_offset0": 16777216,
    "ycc_to_rgb_offset1": 134217728,
    "ycc_to_rgb_offset2": 134217728,
    "rgb_to_lms_coef0": 7222,
    "rgb_to_lms_coef1": 8771,
    "rgb_to_lms_coef2": 390,
    "rgb_to_lms_coef3": 2654,
    "rgb_to_lms_coef4": 12430,
    "rgb_to_lms_coef5": 1300,
    "rgb_to_lms_coef6": 0,
    "rgb_to_lms_coef7": 422,
    "rgb_to_lms_coef8": 15962,
    "signal_eotf": 65535,
    "signal_eotf_param0": 0,
    "signal_eotf_param1": 0,
    "signal_eotf_param2": 0,
    "signal_bit_depth": 12,
    "signal_color_space": 0,
    "signal_chroma_format": 0,
    "signal_full_range_flag": 1,
    "source_min_pq": 7,
    "source_max_pq": 3079,
    "source_diagonal": 42,
    "cmv29_metadata": {
      "num_ext_blocks": 3,
      "ext_metadata_blocks": [
          "Level1": {
            "min_pq": 0,
            "max_pq": 2894,
            "avg_pq": 1178
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 276,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 825,
            "max_frame_average_light_level": 118
    "cmv40_metadata": {
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reference_mode_flag": true,
            "reserved_byte2": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 3531511101
"The script has completed."
deadchip12 wrote: Fri May 27, 2022 1:57 pm Using tsmuxer to convert those mkv files to .ts seems to solve the problem. Is that the right way to do it?
yep that's the way.
realbabilu
Post by realbabilu » Fri May 27, 2022 2:57 pm
Yup it needed to install LAV Splitter. now encoding rpu at dxva2.
Succeed converting HDR10 to DV P8
Do you have others FEL Profile 7 sample?
Ypur file in signature: The dual layer FEL P7 detected as HDR10 only in my tv. single layer FEL detected as DV but jitter.
MEL is ok.
NiCE77
Post by NiCE77 » Sat May 28, 2022 8:59 am
RESET_9999 wrote: Fri May 27, 2022 1:46 pm
No, but maybe it's my TV, as it says here: https://community.firecore.com/t/dolby- ... /19713/306
deadchip12
Post by deadchip12 » Sat May 28, 2022 11:32 am
I just downloaded the latest version tsmuxer (date: 25/02/2022) and when I add a movie file in it, it reports an error and doesn't show the dolby vision video track. Going back to a previous version of tsmuxer (date: 23/01/2022) and it works fine. Is there something wrong with the latest version of tsmuxer?
Old version of tsmuxer:
New version of tsmuxer:
deadchip12
Post by deadchip12 » Sat May 28, 2022 1:40 pm
RESET_9999 wrote: Fri May 27, 2022 2:46 pm
yep that's the way.
Thanks.
By the way, I just connected my external hdd to the x700 but it is not recognized. The external hdd is a usb 3.0 4TB WD hard drive. I read on Sony website that the max usb storage device size that the x700 can support is 4TB (GTP). I checked the hdd and its partition style is already GTP, so I'm not sure what's the problem here. I have another external hdd which is a usb 2.0 320GB Transcend hard drive and it is recognized immediately by the x700.
Post by Billycar11 » Sat May 28, 2022 1:52 pm
deadchip12 wrote: Sat May 28, 2022 1:40 pm
yep that's the way.
Thanks.
Throwing a guess out maybe the drive is ntfs and it needs to be exfat?
deadchip12
Post by deadchip12 » Sat May 28, 2022 2:02 pm
Billycar11 wrote: Sat May 28, 2022 1:52 pm
yep that's the way.
Thanks.
Both drives are ntfs. On Sony website it also says all formats (ntfs, fat32, exfat) are supported.
realbabilu
Post by realbabilu » Sat May 28, 2022 4:30 pm
deadchip12 wrote: Sat May 28, 2022 2:02 pm
Thanks.
Try format using GPT with 2gb each partition. Worked at my Hisense TV. So 4TB you will have 3 partition minimal. 1 FAT for GPT (ill say may 200mb min, mine about 100gb for TEST DV ATMOS SURROUND HDR mp4 file etc.), 2 partition NTFS around less a bit than 2GB. Free Minitool Partition software recommended.
Sorry that was for internal android tv player.
For sony X700, i dont have. it may only seek first partition. https://www.sony-asia.com/electronics/s ... s/00013721
my bad. Try reducing little bit size of partition instead full 4tb, maybe could help.
DiscoD
Post by DiscoD » Sun May 29, 2022 12:14 am
I have been lurking this thread for a while and its has been an incredible source of information for me,
I do have one question...
If i have a Remux that has already been made from 2 sources(hybrid) Bluray and WEB DV5 converted to 8.1 and synced then injected to create the 8.1 with hdr fallback remux.....
if i wanted to encode that remux do i need to re-sysnc the RPU or will the extracted RPU already be synced, im assuming once the RPU is synced once and i extract it untouched it should then sync up with my encode flawlessly since the original remux i took it from was synced....
any help is appreciated..
rkjnsn
Post by rkjnsn » Sun May 29, 2022 12:18 am
If I have a profile 5 DV video with a 2.40:1 aspect ratio, is there any way to prevent the dark gray bars added by the x700 from changing brightness in response to the DV data? I don't think I'd mind the bars being dark gray by itself, but the flickering is distracting. (Short of reencoding the video to add black bars, that is. This is with TV-led DV on a C1.)
