Pioneer BDR-S12UHT
Pioneer BDR-S12UHT
Pioneer BDR-S12UHT Firmware 1.02
- Captura de ecrã 2022-05-26 225933.png (107.98 KiB) Viewed 39805 times
Re: Pioneer BDR-S12UHT
And?
Can update to 1.02, Not UHD frendely but can rip blurays
You should be able to rip UHD with that
Yes. With makenkv i can.
I have FW 1.01 on my BDR-S12U.
Weren't you afraid to lose UHD rip capabilities when updating? And may I ask how you did that?
TeddyRaspin
You will never lose UHD rip capabilities because the new firmware adds only few improvementsArArdin wrote: Fri May 27, 2022 2:20 pm I have FW 1.01 on my BDR-S12U.
while the libredrive mode is running in RAM (firmware is not overwritten).
In order to upgrade fw, here is the link:
https://pioneer.jp/cgi-bin/device/downl ... W102EU.exe
You have to scrool down page and press "AGREE" button in order to download fw file.
Thanks a bunchTeddyRaspin wrote: Fri May 27, 2022 2:28 pmYou will never lose UHD rip capabilities because the new firmware adds only few improvements
I replaced LG BH16NSS55 with Pioneer BDR S12UHT.
It reads everything, without any noise.
Great improvement.
I can play my UHD discs using MPC HC and Madvr !
Great improvement.
Version 1.03
https://pioneer.jp/cgi-bin/device/downl ... W103EU.exe
Change point :
1.03
- Improvement of the playback operation with specific media
1.02
1.01
- Support New BD-R TL media(4x Writing : RiTEK)
- Improvement of the operational stability when BD-R SL 16x speed recording.
- Improvement of the operational stability when recording CD, DVD, BD.
Change point :
1.03
1.02
1.01
well i just got burned by this post. Went to 1.04 firmware and lost libre. Two brand new never used drives.TeddyRaspin wrote: Fri May 27, 2022 2:28 pmYou will never lose UHD rip capabilities because the new firmware adds only few improvementsArArdin wrote: Fri May 27, 2022 2:20 pm I have FW 1.01 on my BDR-S12U.
Mike the developer said few weeks for a fix
TeddyRaspin
A fix will come. Keep your drives safe.gerard143 wrote: Mon Mar 06, 2023 2:46 am
Proeliator
Hi, any updates on this? It's been a few months. It's showing the following for my BDR-S12UHT:
Drive platform: Pioneer RS8F01
Firmware version: ID43
Show the whole status information. If your firmware date is Dec. 2022 or later you have to wait.
