quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri May 27, 2022 1:37 am
thank you
Just tried and the same bug as all the files I did
Okay, last attempt: https://0x0.st/oB-i.mkv
This is just the Resolve file reencoded.
quietvoid wrote:
Fri May 27, 2022 2:13 am
no bug for that one.
So it means there's an issue in the source that Resolve somehow manages to fix, and it's only affecting the Shield.
So weird...
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri May 27, 2022 2:54 am
So weird...
Not necessarily, I had changed an encoding setting.
Same settings with the non-Resolve video: https://0x0.st/oB-c.mkv
If that still has issues, then not sure.
The only difference in the Resolve image is that I can't seem to match chroma alignment, and it has less banding in the blue part.
quietvoid wrote:
Fri May 27, 2022 3:06 am
bug is back lol
I wonder what magic resolve does.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri May 27, 2022 3:10 am
bug is back lol
I guess this is my actual last attempt then: https://0x0.st/oB-B.mkv
It doesn't make sense that the original test pattern causes issues.
same issue...
I tried NVenc, same issue.
I tried FFmpeg to prores to x265, same issue.
quietvoid
Post by quietvoid »
Clearly the file I have is wrong:
So the only possibibility is that you encoded something else in Resolve.
Or that it did some tone mapping, maybe.
https://slow.pics/c/iu90f2Sp
The answer is definitely that Resolve tone mapped the image, which corrects the gradients.
This is also why Resolve's luma and chroma clip earlier than the original.
NiCE77
Post by NiCE77 »
@quietvoid
Someone replied on the Firecore forum about Apple TV RPU management:
"Apple devices always ignore L2 trim in profile 8.4 video. Actually there are two version of Apple’s profile 8.4, the early version is L1 only and old OS (like ios14) doesn’t handle trims at all (except profile 5). The recent version uses newer algorithm which needs L8 trim."
https://community.firecore.com/t/dolby- ... /19713/302
quietvoid wrote:
Fri May 27, 2022 3:32 am
still doesnt make sense.
The file is the original one unless the bd rip I downloaded got messed up. I dont see how it would cause a luma difference like that and IIRC, the PQ image were identical.
And even stranger, how can it just affect the Shield. And no we did not encode "something" else in resolve.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri May 27, 2022 11:03 am
Of course it makes sense. The input was probably color managed in Resolve, making it tone map.
The metadata shows it: 1000 nits mastering, DCI-P3.
So the Shield apparently doesn't do well with tone mapping from 10k nits + BT.2020 in YCbCr, even with Dolby Vision.
The files only look similar with all planes combined. See single planes: https://slow.pics/c/ZoxjvanI
So what likely happened is that Resolve converted from 10k nits BT.2020 to 1000 nits DCI-P3.
NiCE77 wrote:
Fri May 27, 2022 5:43 am
@quietvoid
Yeah, I know. Eventually I'll make a CM v4.x only file.
quietvoid wrote:
Fri May 27, 2022 11:38 am
no, the Resolve encoded file is still 10 000nits.
As for the color management in resolve, you might be right.
so do you see an L1 response with the 8.4 sample ?
realbabilu
Post by realbabilu »
Video
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 1 h 50 min
Bit rate                                 : 17.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.090
Stream size                              : 13.8 GiB (96%)
Writing library                          : x265 3.4hy:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=1 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=96 / keyint=96 / gop-lookahead=0 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=18000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=24500 / vbv-bufsize=24500 / vbv-init=0.6 / vbv-end=0.6 / vbv-end-fr-adj=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=825,118 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / no-concatenation / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Encoded date                             : UTC 2022-05-27 13:38:54
Tagged date                              : UTC 2022-05-27 13:38:54
Maximum Content Light Level              : 825 cd/m2
Maximum Frame-Average Light Level        : 118 cd/m2
Codec configuration box                  : hvcC
Drag and drop your MKV file and press enter...E:\mov\tor\Mortal.Kombat.2021.2160p.mkv
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped) and/or press enter...n
Measuring the HDR10 video letterbox...
min: 0.0001 cd/m2, max: 1000 cd/m2
Maxcll: 825
Maxfall: 118
LAV Splitter Source not found.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Parsing madVR measurement file...
Error: The system cannot find the file specified. (os error 2)
any clue with HDR10 inject auto?
deadchip12
Post by deadchip12 »
@RESET_9999
I have a question regarding the x700: some mkv dolby vision movie files or mkv sdr movie files have dolby atmos dd+ 5.1 and the bluray player refuses to play the audio track. Using tsmuxer to convert those mkv files to .ts seems to solve the problem. Is that the right way to do it? Any drawbacks to picture or sound quality?
realbabilu wrote:
Fri May 27, 2022 1:56 pm
Just tried that bluray remux and no issue, so there might be something going on with your encode.
1) Workflow.1= INJECT + AUTO-L5 + INJECT DV
2) Workflow.2= INJECT + MANUAL-L5 + INJECT DV
3) Workflow.3= INJECT + MANUAL-L5 + INJECT DV + TrueHD_to_TrueHD.ac3 + DDP_1536kbps
4) Workflow.4= INJECT + MANUAL-L5 + INJECT DV + TrueHD_to_TrueHD.ac3
5) Workflow.5= INJECT + MANUAL-L5 + INJECT DV + DDP_1536kbps
6) Workflow.6= Back to main menu
Choice? [1,2,3,4,5,6]?1
--input must be HDR10 MKV
--This workflow will measure HDR10, generate RPU, auto edit L5 and inject
--The black bars detection may not be perfectly accurate. It's maybe better to measure them manually
Drag and drop your MKV file and press enter...S:\Mortal.Kombat.2021.HDR.mkv
Maxcll: 825
Maxfall: 118
Measuring video file "S:\Mortal.Kombat.2021.HDR.mkv" using D3D11 (native)...
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 825, MaxFALL: 118 nits
Measurements:
  Frames: 158329, MaxCLL 100%: 1117, 99.9%: 994, MaxFALL: 562, AvgFALL: 11, AvgFMLL: 307 nits
Progress: 100%
Generating metadata...
Generated metadata for 158329 frames
Done.
EditConfig {
    mode: 0,
    convert_to_cmv4: false,
    remove_mapping: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 276,
                        bottom: 276,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Editing active area offsets...
Final metadata length: 158329
Writing RPU file...
Parsing RPU file...
Processing input video for frame order info...
Warning: Input file already has RPUs, they will be replaced.
Computing frame indices..
Rewriting file with interleaved RPU NALs..
Parsing RPU file...
  "dovi_profile": 8,
  "header": {
    "rpu_nal_prefix": 25,
    "rpu_type": 2,
    "rpu_format": 18,
    "vdr_rpu_profile": 1,
    "vdr_rpu_level": 0,
    "vdr_seq_info_present_flag": true,
    "chroma_resampling_explicit_filter_flag": false,
    "coefficient_data_type": 0,
    "coefficient_log2_denom": 23,
    "vdr_rpu_normalized_idc": 1,
    "bl_video_full_range_flag": false,
    "bl_bit_depth_minus8": 2,
    "el_bit_depth_minus8": 2,
    "vdr_bit_depth_minus_8": 4,
    "spatial_resampling_filter_flag": false,
    "reserved_zero_3bits": 0,
    "el_spatial_resampling_filter_flag": false,
    "disable_residual_flag": true,
    "vdr_dm_metadata_present_flag": true,
    "use_prev_vdr_rpu_flag": false,
    "prev_vdr_rpu_id": 0,
    "vdr_rpu_id": 0,
    "mapping_color_space": 0,
    "mapping_chroma_format_idc": 0,
    "num_pivots_minus_2": [
      0,
      0,
      0
    "pred_pivot_value": [
        0,
        1023
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "nlq_pred_pivot_value": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "rpu_data_mapping": {
    "mapping_idc": [
        0
        0
        0
    "mapping_param_pred_flag": [
        false
        false
        false
    "num_mapping_param_predictors": [
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
    "poly_order_minus1": [
        0
        0
        0
    "linear_interp_flag": [
        false
        false
        false
    "pred_linear_interp_value_int": [
    "pred_linear_interp_value": [
    "poly_coef_int": [
          0,
          1
          0,
          1
          0,
          1
    "poly_coef": [
          0,
          0
          0,
          0
          0,
          0
    "mmr_order_minus1": [
    "mmr_constant_int": [
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
  "vdr_dm_data": {
    "compressed": false,
    "affected_dm_metadata_id": 0,
    "current_dm_metadata_id": 0,
    "scene_refresh_flag": 0,
    "ycc_to_rgb_coef0": 9574,
    "ycc_to_rgb_coef1": 0,
    "ycc_to_rgb_coef2": 13802,
    "ycc_to_rgb_coef3": 9574,
    "ycc_to_rgb_coef4": -1540,
    "ycc_to_rgb_coef5": -5348,
    "ycc_to_rgb_coef6": 9574,
    "ycc_to_rgb_coef7": 17610,
    "ycc_to_rgb_coef8": 0,
    "ycc_to_rgb_offset0": 16777216,
    "ycc_to_rgb_offset1": 134217728,
    "ycc_to_rgb_offset2": 134217728,
    "rgb_to_lms_coef0": 7222,
    "rgb_to_lms_coef1": 8771,
    "rgb_to_lms_coef2": 390,
    "rgb_to_lms_coef3": 2654,
    "rgb_to_lms_coef4": 12430,
    "rgb_to_lms_coef5": 1300,
    "rgb_to_lms_coef6": 0,
    "rgb_to_lms_coef7": 422,
    "rgb_to_lms_coef8": 15962,
    "signal_eotf": 65535,
    "signal_eotf_param0": 0,
    "signal_eotf_param1": 0,
    "signal_eotf_param2": 0,
    "signal_bit_depth": 12,
    "signal_color_space": 0,
    "signal_chroma_format": 0,
    "signal_full_range_flag": 1,
    "source_min_pq": 7,
    "source_max_pq": 3079,
    "source_diagonal": 42,
    "cmv29_metadata": {
      "num_ext_blocks": 3,
      "ext_metadata_blocks": [
          "Level1": {
            "min_pq": 0,
            "max_pq": 2894,
            "avg_pq": 1178
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 276,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 825,
            "max_frame_average_light_level": 118
    "cmv40_metadata": {
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reference_mode_flag": true,
            "reserved_byte2": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 3531511101
"The script has completed."
deadchip12 wrote:
Fri May 27, 2022 1:57 pm
yep that's the way.
