Unable to rip Inception
Hi everyone. I was unable to rip Inception so I did a full disk backup as I figured might be requested. I will upload the debug log with both attempts (at the bottom).
- Contact:
Re: Unable to rip Inception
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 803923968, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 804120576, file is corrupt.Re: Unable to rip Inception
Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
Could be dirty; try cleaning it.ericnyc wrote:Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
- Contact:
Well, it means that the file that was read from the disc is certainly corrupted. Content hash file is like md5sum file for each M2TS file. So yes, hashcheck error is either a bad disc or drive.ericnyc wrote:Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
