quietvoid
Post by quietvoid » Mon May 23, 2022 2:46 am
RESET_9999 wrote: Mon May 23, 2022 2:40 am The shield supports LLDV, the x700/x800m2 as well.
They just don't have an option in the display settings to select it. instead they use the TV EDID to choose the DV mode.
Okay, not sure then. It might just be a bug with the older Sony TVs.
Unknown
Post by Unknown » Mon May 23, 2022 3:35 am
Unknown wrote: Sun May 22, 2022 2:59 pm hi, I tried everything possible script, Nothing allows me to watch my movie in Dolby Vision on my LG C1 it always shows me the logo "HDR" I convert profile 7 dual layer to profile 8 still does not work, If anyone can help me it would be so nice I at the bottom of the barrel after almost a week of research :cry:
That's strange, I assume you tried my scripts?
if not then try the mp4muxer P8 modes or nightly tsmuxer.
I tested your script the movie I wanted to convert to MP4 DVI to work perfectly I had not seen your script in your description, Thank you for your work 8)
NiCE77
Post by NiCE77 » Mon May 23, 2022 3:26 pm
quietvoid wrote: Sun May 22, 2022 3:09 am
NiCE77 wrote: Sun May 15, 2022 4:05 pmI have an Apple TV 4K 2021 and an iPhone 12 Pro Max, so I can help.
I've added profile 8.4 generation based on iPhone 13 RPU samples.
Profile 8.4 L2 tests: https://mega.nz/file/0RMX1I5b#eULlLdOrg ... BRERfgWICw
It might need to be remuxed depending on your device.
Also remade the L2 test file in CM v4.x with the minimum required blocks, so it's still L2 only.
Profile 8.1: https://mega.nz/file/tc0nkBjY#LsBfxDMUh ... EUXe2vjCgg
For profile 8.4 HLG I tested it on my side and it works. I can't see a difference between 8.1 and 8.4 by eye.
FireTV Stick 4K Max (2021, latest update): plays in Dolby Vision, L2 metadata works.
FireTV Stick 4K (2018, old update): plays in HLG, wrong colours.
I've blocked updates on my 2018 stick, so I can't test if it was added.
If anyone wants to test on other devices, feel welcome.
Many thanks, I'm tried with Apple TV 4K 2021 + Infuse, but the ATV does not handle the RPU. I will report to the Firecore forum.
rophel
Post by rophel » Tue May 24, 2022 5:26 am
Using Reset_9999's scripts and had some questions:
How accurate is the conversion of HDR10plus to DV? Anything I can do to improve the conversion? I don't have an HDR10+ display to compare.
Also, sometimes I end up with both an .hevc and a .bin file when using the script, etc. Do I need to do anything with the .bin or just mux the .hevc into a mkv? I'm not losing anything by discarding the .bin, correct? S
NiCE77
Post by NiCE77 » Tue May 24, 2022 6:21 am
@quietvoid:
I also created mp4 and ts versions of your test files: https://1drv.ms/u/s!Ahh4FiB9hIuT-ETf93f ... D?e=nOgBuQ
Is it possible that the Apple TV could only read the RPU from the mov container? How can I make a mov file?
quietvoid
Post by quietvoid » Tue May 24, 2022 12:17 pm
NiCE77 wrote: Tue May 24, 2022 6:21 am @quietvoid:
Not sure. ffmpeg isn't keeping the Dolby Vision config when converting to mov. Only mp4.
Post by RESET_9999 » Tue May 24, 2022 10:56 pm
rophel wrote: Tue May 24, 2022 5:26 am Using Reset_9999's scripts and had some questions:
nop, you cannot improve the conversion. it's the best you can get with the input source you have.
rophel wrote: Tue May 24, 2022 5:26 am Also, sometimes I end up with both an .hevc and a .bin file when using the script, etc. Do I need to do anything with the .bin or just mux the .hevc into a mkv? I'm not losing anything by discarding the .bin, correct? S
you can delete the .bin file.
I keep a copy because I want to share the rpu with my friends.
rkjnsn
Post by rkjnsn » Tue May 24, 2022 11:44 pm
For movies with neither a Dolby Vision track nor HDR10+ metadata to convert, how much of a difference am I likely to notice on an LG C1 between auto-generating shot-by-shot metadata versus just playing it back with static metadata? Is it more likely to make a difference in a brighter room (so Dolby Vision IQ can do its thing) than a fully dark room?
Finally, is there any way to generate shot-by-shot metadata on Linux, or do I have to use the madMeasureHDR.exe program under Windows?
Thanks.
Post by Manixx2020beyound » Tue May 24, 2022 11:57 pm
I just made a profile 5 doblyvision encode (now-possible) encoded on a pc
This test was made from a hdr10 base layer.
And it works on apple 🍎 tv
I’ll wait for reset9999 to compare
Post by RESET_9999 » Wed May 25, 2022 12:12 am
rkjnsn wrote: Tue May 24, 2022 11:44 pm For movies with neither a Dolby Vision track nor HDR10+ metadata to convert, how much of a difference am I likely to notice on an LG C1 between auto-generating shot-by-shot metadata versus just playing it back with static metadata? Is it more likely to make a difference in a brighter room (so Dolby Vision IQ can do its thing) than a fully dark room?
Thanks.
HDR10 with madvr-generated DV is certainly better than just static HDR10. You will notice a difference, especially with bright content.
I dont know about Linux.
Post by Manixx2020beyound » Wed May 25, 2022 3:05 am
Manixx2020beyound wrote: Tue May 24, 2022 11:57 pm I just made a profile 5 doblyvision encode (now-possible) encoded on a pc
My p5 are triggering doblyvision on the pc app. This is unbelievable
rophel
Post by rophel » Wed May 25, 2022 3:24 am
@RESET_9999 Thanks for the quick reply!
Another issue (and I've spent time searching the forum via Google so sorry if this has been covered):
When I do WEB-DL only hybrids i.e. both DV and HDR are from WEB-DLs, with most films I get audio that is wildly out of sync. TV shows have no issues, strangely. Source files are MKVs, I use the hybrid maker script, then mux the resulting hevc file with the HDR file's audio and subs using mkvtoolnix gui.
I saw some mention of trying better release groups, but has anyone had any success in resolving this? I am using two files from the same release group and confirm exact same length via jumping to specific frames, etc.
I tried some various things, using TSMuxer to turn the end MKV into a TS seemed to get the audio only a second or so off...while the MKV was WILDLY off. So odd.
Post by Manixx2020beyound » Wed May 25, 2022 7:51 am
Here is a p5 sample for u guys to test
This was encoded using doblyvision encoding engine & h265, RPU is a true P5 even l4 included
Source file spares & munsil m2ts untouched Mel.
Test on Apple TV’s
https://drive.google.com/file/d/1476mVd ... sp=sharing
Last edited by Manixx2020beyound on Wed May 25, 2022 3:59 pm, edited 1 time in total.
NiCE77
Post by NiCE77 » Wed May 25, 2022 9:52 am
Manixx2020beyound wrote: Wed May 25, 2022 7:51 am Here is a p5 sample for u guys to test
Test on Apple TV’s
https://drive.google.com/file/d/14VpI6o ... p=drivesdk
Thanks, I will try tonight. Maybe you could make a mov file from the recently linked P8.4 L2 test file?
ragico
Post by ragico » Wed May 25, 2022 1:27 pm
Test on Apple TV’s
Thank you. Tested on ATV 4k works perfectly via Infuse but no audio.
Also for a couple of secs woksr on plex app before a message appears on the screen, plex complaining the network speed is too low (it is wired gigabit).
