#6571 Post by RESET_9999 » Fri May 20, 2022 2:18 pm
Tormented12 wrote:
Fri May 20, 2022 2:09 pm
RESET_9999 wrote:
Fri May 20, 2022 2:05 pm
Ha, the total duration doesn't matter as long as it's the same director cut or theatrical cut. When I do hybrid, there's 95% of the time a mismatch length, all normal.
Ahh alright. But something like this: if i open Episode 1 - HDR, and Episode 1 - DV, and go to the same frame, the frame (like you showed with Onward), isn't matching. Do I need to correct that difference on the frontside only now? Since it duplicated at the end?
yes of course, you have to remove or duplicate frames otherwise the rpu wont be in sync with the HDR10 BL. The only thing you can ignore is the mismatch warning at the end.
check my dovi scripts, there are tutorial videos
phbart
#6572 Post by phbart » Sat May 21, 2022 6:41 pm
I don't know if this has been clarified before. It's about the X700 Dolby Vision capabilities. I noticed that when I play an m2ts video file that I know is in DV, the OSD of the player does not show it as a DV content, but it does trigger DV on my TV (LG B7P).
(Ghostbusters m2ts with DV):
When I play an mp4 file, the player's OSD show that it is DV (and naturally, it triggers it on the TV as well).
(Parasite mp4 remux with DV):
The thing is that when I play an m2ts that it's in HDR10, it still triggers DV, like the example below.
(Sex, Lies and Videotape with HDR10):
Sooooo, the question is... is there a way we know for sure that the X700 is correctly playing an m2ts with DV instead of "artificially converting" it like it does with non-DV m2ts files?
#6573 Post by RESET_9999 » Sat May 21, 2022 7:14 pm
you have to remux your BD with nightly tsmuxer and then you'll get true DV with m2ts/ts files. The x700 osd will confirm it
https://github.com/justdan96/tsMuxer/releases
phbart
#6574 Post by phbart » Sat May 21, 2022 9:07 pm
I didn't realize that.
Thank you so much! :wink:
realbabilu
#6575 Post by realbabilu » Sun May 22, 2022 2:40 am
Research playing DV on my cheapest Android TV Hisense 55E7G:
1. Dolby Vision MP4 remux always works, subtitle should be outside same name, on srt or ass version. all normals at FF/RW
2. Dolby Vision TS remux by TSmuxer nightly, sometimes smooth, sometimes can't be played at all(even in PC!), subtitle not in sync. Buggy.
To Dovi script author.
1. For MKV to MP4, with PGS Subtitle included, it shall be continue process with asking for additonal SRT file instead stop it. And there is a workway just remux the audio stream, EAC/AC3 with Atmos, no need of decoding or convert it. OR there is mkv muxer script with removing SUP subtitle and adding SRT instead.
Mode 5 - MKV to TS,
Failed to auto-detect SRT encoding : falling back to the active code page
Invalid SRT format. "PG" is invalid timing info
Decoding E-AC3 (DD+) stream (track 2): Bitrate: 538Kbps (core 0Kbps) Sample Rate: 48KHz Channels: 7.1
2. For MP4 muxing from Mode.M4
Only 1 SRT subtitle can be added. Cant add more?
Seems not working on my Hisense for showing subtitle inside.
I Will try with subler for comparison instead, but need a hackintosh for use it. Usually worked for my old HD samsung TV.
quietvoid
#6576 Post by quietvoid » Sun May 22, 2022 3:09 am
NiCE77 wrote:
Sun May 15, 2022 4:05 pm
I have an Apple TV 4K 2021 and an iPhone 12 Pro Max, so I can help.
I've added profile 8.4 generation based on iPhone 13 RPU samples.
Profile 8.4 L2 tests: https://mega.nz/file/0RMX1I5b#eULlLdOrg ... BRERfgWICw
It might need to be remuxed depending on your device.
Also remade the L2 test file in CM v4.x with the minimum required blocks, so it's still L2 only.
Profile 8.1: https://mega.nz/file/tc0nkBjY#LsBfxDMUh ... EUXe2vjCgg
For profile 8.4 HLG I tested it on my side and it works. I can't see a difference between 8.1 and 8.4 by eye.
FireTV Stick 4K Max (2021, latest update): plays in Dolby Vision, L2 metadata works.
FireTV Stick 4K (2018, old update): plays in HLG, wrong colours.
I've blocked updates on my 2018 stick, so I can't test if it was added.
If anyone wants to test on other devices, feel welcome.
box4m
#6577 Post by box4m » Sun May 22, 2022 9:39 am
Do we have any ppl on this thread with Chromecast with GTV? CCWGTV i believe its called
Its suppose to support profile 7 FEL dolby vision, but the infamous excelshart has no info about CCWGTV really
If anyone who has it and uses it for this purpose could explain how well it works etc?
#6578 Post by RESET_9999 » Sun May 22, 2022 1:41 pm
@quietvoid thank you
@box4m
I had the CCWGTV for only a few days and it did play FEL MKVs in PLEX but the problem was that if you FF/RW/resume, the EL went out of sync.
Also, it defaults to LLDV instead of regular TV-LED.
it was a while ago, so it may have been fixed by now.
box4m
#6579 Post by box4m » Sun May 22, 2022 2:10 pm
@box4m
Thank you
My TV can not do TV-LED DV anyway so thats not a problem for me.
But the out of sync might be
Maybe someone else will comment on this
Or i will just buy and try
Unknown
#6580 Post by Unknown » Sun May 22, 2022 2:59 pm
hi, I tried everything possible script, Nothing allows me to watch my movie in Dolby Vision on my LG C1 it always shows me the logo "HDR" I convert profile 7 dual layer to profile 8 still does not work, If anyone can help me it would be so nice I at the bottom of the barrel after almost a week of research :cry:
#6581 Post by RESET_9999 » Sun May 22, 2022 5:18 pm
Mode 5 - MKV to TS,
update to the latest version, it sounds like you're using an older version. I did many changes in the mp4muxer mode recently.
1:
-MKV P7 to MP4 (workflows 4-5) now includes SRT subtitles only if present in the source (no more external option). And sorry, I'm not converting PGS to SRT and wont add support for that. In my experience, OCR always needs manual verification.
-MP4 modes are not converting audio if the input contains AC3 or EC3 track.
Mode 5 - MKV to TS:
MKV to TS batch mode is working on my end... did you try the file in tsmuxer? some SRT track wont works sometimes.
--This workflow will mux up to 13 DoVi MKV to TS, (video / audio / sub)
Drag and drop your DV MKV file #1 and press enter...
"D:\p5 - Copie - Copie.mkv"
Drag and drop your DV MKV file #2 and press enter...
"D:\p5 - Copie - Copie (2).mkv"
Drag and drop your DV MKV file #3 and press enter...
"D:\p5 - Copie - Copie (3).mkv"
Drag and drop your DV MKV file #4 and press enter...
"D:\p5 - Copie - Copie (4).mkv"
Drag and drop your DV MKV file #5 and press enter...
tsMuxeR version git-f4fa419. github.com/justdan96/tsMuxer
HEVC muxing fps is not set. Get fps from stream. Value: 23.976
B-pyramid level 1 detected. Shift DTS to 2 frames
0.1% complete
Decoding E-AC3 (DD+) stream (track 2): Bitrate: 768Kbps (core 0Kbps) Sample Rate: 48KHz Channels: 5.1
Decoding PGS stream (track 3):  Resolution: 1920:1080  Frame rate: 23.976
93.8% complete
Processed 10103 video frames
100.0% complete
Flushing write buffer
Mux successful complete
Muxing time: 2 sec
0.1% complete
95.0% complete
100.0% complete
Muxing time: 2 sec
0.1% complete
89.2% complete
100.0% complete
Muxing time: 2 sec
0.1% complete
91.6% complete
100.0% complete
Muxing time: 2 sec
The script has completed , no more file to process...
Appuyez sur une touche pour continuer...
2:
Workflow.1= ANY VIDEO + ANY AUDIO(lossless audio included) + SRT subtitle(external) : if you demux your files, it can do pretty much anything now. 2 audio 2 srt / no srt no audio / 2 audio no srt / 1audio 1srt etc...
That's strange, I assume you tried my scripts?
if not then try the mp4muxer P8 modes or nightly tsmuxer.
#6582 Post by RESET_9999 » Sun May 22, 2022 10:27 pm
mmm, L1/L2 is ignored in LLDV... @manix just tested the Shield, x700 and Dune player.
so the LLDV bug is even worse than we thought??
got curious after reading this comment on the nvidia forum:
phbart
#6583 Post by phbart » Sun May 22, 2022 11:46 pm
I tried the latest version, but it's still not triggering DV. I remuxed as "blu-ray disc". Do I need to change the mux settings?
quietvoid
#6584 Post by quietvoid » Mon May 23, 2022 1:19 am
I guess. Did it work with the previous test version?
#6585 Post by RESET_9999 » Mon May 23, 2022 2:16 am
We did not test LLDV with the first version but @GREMez comment is about it.
Interestingly, it may be a different problem than the one described in Vincent video because with the Dune player set to LLDV in the display settings(instead of using the vertex), now L1/L2 is working.
There are no LLDV options on the Shield/x700, it can only be forced with an hdfury device or a LLDV TV.
