My films are in bluray folder structure, so I used tsmuxer to demux the subtitle file. I followed the instructions but got this error:uhdiznotenough4mee wrote: ↑Wed May 18, 2022 4:23 pmDemux them using eac3to or DGDemux for example -> put them in some folder named "subs" -> create another folder inside folder "subs" named "tonemapped" -> open subtitle_tonemap.exe in cmd.exe and use this command: subtitle_tonemap.exe "C:\bin\subs" -o "C:\bin\subs\tonemapped" -p 60deadchip12 wrote: ↑Wed May 18, 2022 4:08 pmThanks for the exe file. How do I extract the pgs sub file from the film's bluray folder and reattach the tonemapped version to the film?uhdiznotenough4mee wrote: ↑Wed May 18, 2022 4:04 pm
You need to tonemap your pgs subs before you mux them.
Here (of course if you are using Win): https://github.com/quietvoid/subtitle_t ... s-msvc.zip
-o = output
-p = % to multiply the final color of the subtitle. Defaults to 60%
-> mux them with MKVToolnix to your video file... that's it, done.
