Thanks to quietvoid you can use this great tool: https://github.com/quietvoid/subtitle_tonemapdeadchip12 wrote: Wed May 18, 2022 9:49 am Does anyone know a way to reduce the brightness of subtitles in hdr? They are blinding in dark scenes.
- put "BDSup2Sub512.jar" inside the folder with "subtitle_tonemap.exe"
- example of usage: subtitle_tonemap.exe "folder_with_pgs_subs" -o "folder_with_tonemapped_subs" -p 62
- the path to folders with .pgs subs should end without "\"
