Original version was 1.00. Got upgraded to 1.05. Everything I'm reading so far says that the tools available only work on 2015 or later.
Asking for an authoritative answer: is this drive completely screwed from being able to downgrade to 1.02? I did try the conventional way (download the driver from LG and try to flash. Obviously that doesn't work).
So is this one too old for any of the solutions presented by MakeMKV? Does anyone know of another way to skin this cat?
LG WH16NS40 SVC NS40 NOVEMBER 2014
Re: LG WH16NS40 SVC NS40 NOVEMBER 2014
Dos flash is the only way now see recovery section in guide.
Thank you very kindly for your reply. I attempted as much and met with a brick wall. It's OK, though. The drive I have is an older one (November 2014), so I shouldn't have expected it to work, but it was worth the effort.Billycar11 wrote: ↑Wed May 18, 2022 3:37 pmDos flash is the only way now see recovery section in guide.
Again, thank you.
Flashing it wasn't worth the effort at all... Researching if it is UHD capable before flashing is worth the effort!!Matt1973 wrote: ↑Wed May 18, 2022 5:32 pmThank you very kindly for your reply. I attempted as much and met with a brick wall. It's OK, though. The drive I have is an older one (November 2014), so I shouldn't have expected it to work, but it was worth the effort.Billycar11 wrote: ↑Wed May 18, 2022 3:37 pmDos flash is the only way now see recovery section in guide.
Again, thank you.
