rkjnsn
Post by rkjnsn »
Is there a good summary of the current state of affairs with respect to playing back backups of discs with Dolby Vision? I'm new to this, having just upgraded to a Dolby-Vision-capable TV, and my searches seem to just drop me into the middle of this thread (or similarly-long threads on other sites), usually a year or two back, and it's hard to tell what's still relevant. (E.g., support for various DV formats on the Shield seem to have improved since the thread started.) Some specific questions:
  • Is it still the case that none of the current generation of network media players have the second HEVC decoder that would be necessary to decode the extra video detail present in FEL tracks?
  • Is there any advantage to something like Dune HD Real Vision 4K, which claims support for "all popular Dolby Vision profiles (P4, P5, P7 MEL and FEL, P8)" with the built-in player (despite apparently not being able to decode the FEL video stream) over what is currently possible with the NVIDIA Shield? What player apps for the Shield support which formats? (It sounded like special builds of some players are/used to be necessary?)
  • How much of an issue is not being able to decode the FEL video stream? It sounded like at one point some films (e.g., Saving Private Ryan) exhibited flickering due to the RPU taking into account luminance changes from the FEL that weren't actually being applied. Has this been resolved or worked around? If so, does it require preprocessing the file to convert it to MEL, or can such files be played back properly with some app(s) on the Shield (or Dune HD) now as is?
  • It looks like some folks got playback working on a couple of Blu-ray players (Oppo players, the Sony x700, and the Sony x800M2) with both FEL decoding and TrueHD audio by using a special build of tsMuxer to remux the movie into a new m2ts file with the appropriate DV flags applied directly to the file.
    • Does this work with with the mainline tsMuxer now?
    • Is this still the best/only way to get full FEL support and TrueHD Atmos at the same time?
    • Does it also work for DTS MA / DTS:X?
    • Is the x800M2 still the only player this is known to work on without the bug where playback breaks for subsequent files?
    • Do these players enforce Cinavia on USB and/or DLNA? (It sounds like maybe Oppo does, but Sony doesn't?)
check the spreadsheet in my signature.
*** I think I found an issue with the x800m2:
1- DTS-HD 2.0 plays only as lossy DTS (core)
2- DTS-HD 7.1 seems to always be out of sync about 2 frames (83MS) but strangely DTS-HD 5.1 is fine.
MastaG
Post by MastaG »
@RESET_9999
Your scripts are awesome.
It seems the older 2016 LG OLED models can only playback DV when packed into mp4 container.
My C8 LG will also play them when muxed into TS or M2TS container.
So for 100% compatibility with all devices, it's best to store in mp4 container, so you can serve everyone with Emby Media Server.
Also go with profile 8 because some TV's have issues with high bitrate BL and full EL.
I have one feature request if possible.
Could you update the script and add the option to concert audio to regular AC3 5.1 (Dolby Digital Dolby without the +) and have the Dolby Digital Plus EAC3 as the second audio track.
So mp4 with:
1. Video
2. AC3
3. EAC3
Reason for this is that DD+ doesn't work over ARC in some cases due to bandwidth limitations.
Also optical and spdif only support AC3 and DTS.
That's why it's nice to have the first audio track being the regular AC3 and add the DD+ as optional second audio track for better quality audio.
MastaG wrote:
Sat May 14, 2022 5:04 pm
Not exactly what you asked but I just quickly added a workflow that can mux dual lossy audio + sub ( I may add lossless audio support in the future).
MODE.M4 ---> MODE.1 ---> Workflow.2
DD+ 1536kbps works via ARC on my C8
realbabilu
Dolby Vision mp4Remux became streched wide?
Post by realbabilu »
I have several convert with mp4muxer from dolby. All successful except several titles profile 8 from pahe.li
The movie became stretched wide....after converted to mp4 using mp4cleaver and mp4muxer dolby. Any clue?
Width : 3 840 pixels
Height : 1 612 pixels
Display aspect ratio :2.40:1
Bits/(Pixel*Frame) :0.036
then become....
Height : 1 616 pixels
Original height : 1 612 pixels
Display aspect ratio : 2.40:1
Bits/(Pixel*Frame) : 0.036
input DV mkv
General
Unique ID                                : 53961545557488463110803255778292519549 (0x28989D9ACF476A8A2FC05EFB613FD27D)
Complete name                            : P:\backup\Logan.2017.2160p.UHD.BluRay.x265.HDR.DV.DD+7.1-Pahe.in.mkv
File size                                : 6.16 GiB
Duration                                 : 2 h 17 min
Overall bit rate                         : 6 420 kb/s
Encoded date                             : UTC 2022-03-05 03:09:39
Writing application                      : mkvmerge v61.0.0 ('So') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Cover                                    : Yes
Attachments                              : cover.jpg
Encoded by                               : Pahe.in™ Team
Notes                                    : If you wish to share this release, please keep everything intact including the file names
Official Site                            : https://pahe.ph
Video
Bit rate                                 : 5 335 kb/s
Stream size                              : 5.12 GiB (83%)
Writing library                          : x265 3.5+12+14-106329cbd:[Windows][GCC 10.3.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=5 / numa-pools=24 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1612 / interlace=0 / total-frames=197641 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=1 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=19.5 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=65000 / vbv-bufsize=55000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0 / conformance-window-right-offset=0 / conformance-window-bottom-offset=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Audio #1
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : A_EAC3
Bit rate                                 : 960 kb/s
Stream size                              : 943 MiB (15%)
converted mp4 ...streched wide.
General
Complete name                            : P:\ATMOS\Logan.2017.2160p.UHD.BluRay.x265.HDR.DV.DD+7.1-Pahe.in.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/iso6/isom/msdh/dby1)
File size                                : 6.04 GiB
Overall bit rate                         : 6 297 kb/s
Encoded date                             : UTC 2022-04-29 03:22:05
Tagged date                              : UTC 2022-04-29 03:22:05
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Stream size                              : 5.12 GiB (85%)
Codec configuration box                  : hvcC+dvvC
Audio
Format                                   : E-AC-3
Codec ID                                 : ec-3
Bit rate                                 : 960 kb/s
Alternate group                          : 2
SOLUTION! GOT it!
The RPU not match size with the Video. Detect and repair with DDVT Tool Dolby Vision RPU Demuxing from DDTOOLS
https://forum.doom9.org/showthread.php?t=183479
Got the mkv fixed and remux to mp4 with mp4muxer.
NiCE77
Post by NiCE77 »
@RESET_9999
I uploaded a good mp4 version from your HLG test file: https://1drv.ms/v/s!Ahh4FiB9hIuT-EK3sg5 ... j?e=RKiQG4
Interestingly, neither Apple TV 4K 2021 nor Dune Real Vision 4K handles RPU from the 8.4 file, only Shield.
I made a capture from my Shield: https://1drv.ms/v/s!Ahh4FiB9hIuT-EPZwIY ... Y?e=8CekDj
MastaG
Post by MastaG »
RESET_9999 wrote:
Sat May 14, 2022 8:13 pm
Thanks, I'll give it a shot :)
But DD+ doesn't work over optical out.
That's why a regular AC3 track as the first one would be nice and a second higher quality DD+ one for the ones who can output that over ARC.
I always get drop-outs every few seconds when outputting DD+ over ARC from my C8 to my Denon receiver.
NiCE77 wrote:
Sun May 15, 2022 7:43 am
@RESET_9999
thanks, but the problem is that the rpu itself is not really profile 8.4: only the container is. We need a real profile 8.4 file and delay the rpu. Iphone recordings are not dynamic I think, so it wouldnt work.
Dune: that doesnt surprise me and it's exactly the reason why I sold my Zidoo: those devices don't like profile 8 and often ignore the RPU or go out of sync in the middle of a movie. I could not trust it anymore.
MastaG wrote:
Sun May 15, 2022 8:03 am
yep, I do get audio drop out too with DD+ in a mp4 container but not in a TS container.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Sun May 15, 2022 12:34 pm
Should be simple to make. Apple uses a static reshaping for HLG to PQ in iPhone recordings.
I would assume they are limited to 1000 nits.
Would need people to test on the Apple TV 4K though, since it supports profile 8.4.
NiCE77
Post by NiCE77 »
quietvoid wrote:
Sun May 15, 2022 2:50 pm
I have an Apple TV 4K 2021 and an iPhone 12 Pro Max, so I can help.
I don't have an ATV4k anymore nor an iPhone but it would be nice to have a true p8.4 test file(only thing missing in my test files).
ragico
Post by ragico »
I and a friend of mine have tested the file on these devices:
Sony X700 and X800m2 does not trigger DV but Sdr
Dune Real Vision 4K triggers DV with internal player
Firestick 4k max triggers Dv using kodi.
ATV 4k triggers sdr both with infuse and plex.
Tv's are Lg C8 and Lg Cx.
ragico wrote:
Sun May 15, 2022 6:52 pm
remux it to TS and it will work. The MP4 version in my dovi test files GD folder should work as well.
Donpoku
Post by Donpoku »
Which files? Also didn't you have a ugoos have you tried on it?
ragico
Post by ragico »
The file posted by @NICE77 on page 438
I sold my ugoos long time ago.
