How to flash LG BU40N for ripping and work with VLC
langruh
#1 Post by langruh » Mon May 09, 2022 5:03 pm
sorry if my questions should be too trivial, but I am still at the very beginning with the 4K UHD drive issue.
I have ordered a LG BU40N and would like to rip 4K Blu-rays with it using MakeMKV and also watch 4K Blu-rays on the TV using MakeMKV and VLC.
Unfortunately, I still have almost no idea of the necessary steps.
The only thing I know by now is that there are several types of Blu-ray drives:
- UHD official drives: These drives are not able to work with MakeMKV and they are also not going to work with MakeMKV with any update.
- UHD friendly drives: These drives should work with MakeMKV and VLC but are not able to rip 4K Blu-rays.
- UHD drives with new firmware: These drives are friendly work with MakeMKV and VLC and are able to rip 4K Blu-rays.
Is this correct?
What I don't know now is what do I need to do to flash my new drive so that I can both rip 4K Blu-rays with MakeMKV and also watch the movies from the 4K Blu-ray on the TV using MakeMKV and VLC.
Do I need to flash multiple firmwares?
Do I have to follow a certain order for this?
Many thanks in advance for your help and please excuse me again if my questions should be too simple.
Re: How to flash LG BU40N for ripping and work with VLC
#2 Post by MartyMcNuts » Tue May 10, 2022 12:10 am
Is this correct?
Read the guide: viewtopic.php?p=74718#p74718
Basically all drives listed in the guide will work just fine with MakeMKV and should also work with MakeMKV's VLC integration.
langruh
#3 Post by langruh » Fri May 13, 2022 9:34 am
You are right.
I got the UHD drive LG BU40N with Firmware 1.0 from 2016.
  • Downloaded "New! The all you need firmware pack", "New! GUI SDF tool" and newest version of MakeMKV-Tool
  • Installed MakeMKV to my Virtualbox Win10 client and setup drive to this client (although I have read not to do so)
  • Started MakeMKV one time, registered and closed it
  • Started GUI SDF tool, selected correct firmware for LG BU40N (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin) and started flashing
  • After finished flashing shut down Virtualbox client system and restarted PC
Now the drive rips first 4K UHD Blu-ray disc with 6x in Virtualbox.
Thank you all for the great work.
#4 Post by Billycar11 » Fri May 13, 2022 12:23 pm
You are right.
You didn't even need to flash it if it was on 1.00, 1.03 is less compatible
sizzleweet
#5 Post by sizzleweet » Fri Sep 29, 2023 8:47 pm
You are right.
How do you know what firmware the drive is when you get it?
#6 Post by Billycar11 » Fri Sep 29, 2023 9:45 pm
You are right.
Makemkv shows in in the drive info section
