makemkv v1.16.7
Nophobia
makemkv v1.16.7
Post by Nophobia » Thu May 12, 2022 4:39 pm
I have installed the new version. However, the system keep claiming that the trial period is over. This was usually resolved by deleting and installing the latest version of the app. This time, it is not working. Some advise please!
Thanks N
Re: makemkv v1.16.7
Post by Woodstock » Thu May 12, 2022 4:45 pm
Because the trial period for the archive has expired.
There is a new key available that is active until the end of this month, after which a newer key will be required.
Nophobia
Re: makemkv v1.16.7
Post by Nophobia » Thu May 12, 2022 4:53 pm
Thanks for the quick Reply. Where is the key that is active until the end of the month?
Re: makemkv v1.16.7
Post by Woodstock » Thu May 12, 2022 5:58 pm
Same place it's always posted: MakeMKV is free while in beta
Nophobia
Re: makemkv v1.16.7
Post by Nophobia » Thu May 12, 2022 9:01 pm
Copy/pasting the code. It accepts it, but then comes back with a message saying the "Evaluation period has ended ..."
What am I doing wrong?
Re: makemkv v1.16.7
Post by dcoke22 » Fri May 13, 2022 3:38 am
Is your system's time and date set correctly?
