Convert manually file backup into encrypted MakeMKV backup
langruh
Post by langruh » Thu May 12, 2022 4:10 pm
i tried to rip an UHD 4K Disc but i got only several error messages.
Then i found this link:
http://www.makemkv.com/errors/read/
And as told in the last paragraph, i saved all files manually to HDD without any errors.
Now i look for the simple way to ".... convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details."
I searched a long time but found no way to convert the copied files into encrypted MakeMKV backup that can be opened by MakeMKV later.
Am i wrong with understanding the last paragraph from the website above?
AngryVirginian
Re: Convert manually file backup into encrypted MakeMKV backup
Post by AngryVirginian » Thu May 12, 2022 4:52 pm
Make the backed up files and folders into an iso. Mount the iso. Then you can run MakeMkv against the mount to create decrypted backup.
Sent from my Pixel 4 XL using Tapatalk
langruh
Post by langruh » Fri May 13, 2022 7:01 am
Thank you for the advice.
I took ImgBurn and after that MakeMKV could rip the 4K film.
Thank you very much.
