Pitch Black German 4K UHD
Rodney M
#1 Post by Rodney M » Wed May 11, 2022 2:04 pm
Send tgz file.
Danke
Boogie2005
Re: Pitch Black German 4K UHD
#2 Post by Boogie2005 » Thu May 12, 2022 11:53 am
Is there a solution to rip this UHD BD?
#3 Post by dcoke22 » Thu May 12, 2022 1:14 pm
Boogie2005 wrote: Thu May 12, 2022 11:53 am Is there a solution to rip this UHD BD?
As per the UHD FAQ, Rodney M did the right thing and emailed the dump. When it is decrypted MakeMKV will download the key. You should email your dump too, since it might be different.
Boogie2005
#4 Post by Boogie2005 » Thu May 12, 2022 3:19 pm
OK, but where is the mail? I can't find it.
Boogie2005
#5 Post by Boogie2005 » Thu May 12, 2022 3:23 pm
I find the mail !
Boogie2005
#6 Post by Boogie2005 » Fri May 13, 2022 1:43 pm
How long do I have to wait until it works again? I sent the mail with my tgz yesterday.
#7 Post by d00zah » Fri May 13, 2022 4:06 pm
Boogie2005 wrote: Fri May 13, 2022 1:43 pm How long do I have to wait until it works again? I sent the mail with my tgz yesterday.
Just below the email address in the FAQ is the section:
I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer....
The FAQ is your friend... :D
Rodney M
#8 Post by Rodney M » Sat May 14, 2022 9:21 am
Unfortunately it still doesn't work, should I send the tgz file again?
Chetwood
#9 Post by Chetwood » Sat May 14, 2022 12:13 pm
According to the FAQ you should wait...
Boogie2005
#10 Post by Boogie2005 » Sun May 15, 2022 7:31 am
I have now sent a second mail. What does the email have to say? And how can I tell if makemkv is fetching an update? I use version 1.16.7.
Boogie2005
#11 Post by Boogie2005 » Mon May 16, 2022 8:38 am
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29396092
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29395172
Das Öffnen der Disk schlug fehl
I still get that reported. Do I have to wait until there is an update for the programme?
Rodney M
#12 Post by Rodney M » Wed May 18, 2022 1:12 pm
Dankeschön! :D
Arndrell
#13 Post by Arndrell » Thu Oct 12, 2023 8:59 pm
Same issue, dump email
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Arndrell
#14 Post by Arndrell » Sat Oct 14, 2023 8:58 am
Now ripped, thank you
Harry 4k
#15 Post by Harry 4k » Mon Apr 15, 2024 4:59 pm
i have se,for pitch black.nt email with dump file
