Unable to rip Inception
ericnyc
#1 Post by ericnyc » Fri Mar 18, 2011 12:43 pm
Hi everyone. I was unable to rip Inception so I did a full disk backup as I figured might be requested. I will upload the debug log with both attempts (at the bottom).
Re: Unable to rip Inception
#2 Post by mike admin » Sun Mar 20, 2011 10:18 am
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 803923968, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 804120576, file is corrupt.
It's a bad disc.
ericnyc
#3 Post by ericnyc » Sun Mar 20, 2011 6:56 pm
Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
Romansh
#4 Post by Romansh » Mon Mar 21, 2011 9:18 am
ericnyc wrote:Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
Could be dirty; try cleaning it.
#5 Post by mike admin » Sat Mar 26, 2011 10:17 am
Well, it means that the file that was read from the disc is certainly corrupted. Content hash file is like md5sum file for each M2TS file. So yes, hashcheck error is either a bad disc or drive.
