unrestricted read speed = more errors?
omk1980
Post by omk1980 » Wed May 11, 2022 5:30 pm
Hi guys-
I have a wh16ns60 drive. I currently have it listed as unrestricted read speed. Will this lead to more read errors and should i change it to a slower speed? Thanks in advance.
Re: unrestricted read speed = more errors?
Post by Billycar11 » Wed May 11, 2022 6:23 pm
omk1980 wrote: Wed May 11, 2022 5:30 pm Hi guys-
Did you change it in the registry?
omk1980
Post by omk1980 » Wed May 11, 2022 7:30 pm
Billycar11 wrote: Wed May 11, 2022 6:23 pm
i did when i was having an issue w/a triple layered disc. but now the registry value is "0" but still says unrestricted on startup
Post by Billycar11 » Thu May 12, 2022 4:02 am
omk1980 wrote: Wed May 11, 2022 7:30 pm
not sure i would just delete the registry string
omk1980
Post by omk1980 » Sat May 14, 2022 3:08 am
Billycar11 wrote: Thu May 12, 2022 4:02 am
tried that but still says unrestricted. i also uninstalled makemkv, deleted the makemkv registry files, and reinstalled but the program still show unrestricted read access. Hope it doesn't cause more read errors.
Post by Billycar11 » Sat May 14, 2022 5:44 am
omk1980 wrote: Sat May 14, 2022 3:08 am
it always says that when the firmware is flashed or you have libredrive compatible firmware.
but it is not activated unless the registry key is there. so if you deleted it your ok.
omk1980
Post by omk1980 » Sat May 14, 2022 11:44 am
Oh. Awesome. Thanks for confirming.
