Hi guys-
I have a wh16ns60 drive. I currently have it listed as unrestricted read speed. Will this lead to more read errors and should i change it to a slower speed? Thanks in advance.
unrestricted read speed = more errors?
Re: unrestricted read speed = more errors?
Did you change it in the registry?omk1980 wrote: Wed May 11, 2022 5:30 pm Hi guys-
omk1980
i did when i was having an issue w/a triple layered disc. but now the registry value is "0" but still says unrestricted on startupBillycar11 wrote: Wed May 11, 2022 6:23 pmDid you change it in the registry?omk1980 wrote: Wed May 11, 2022 5:30 pm Hi guys-
not sure i would just delete the registry stringomk1980 wrote: Wed May 11, 2022 7:30 pm
omk1980
tried that but still says unrestricted. i also uninstalled makemkv, deleted the makemkv registry files, and reinstalled but the program still show unrestricted read access. Hope it doesn't cause more read errors.Billycar11 wrote: Thu May 12, 2022 4:02 amnot sure i would just delete the registry stringomk1980 wrote: Wed May 11, 2022 7:30 pm
it always says that when the firmware is flashed or you have libredrive compatible firmware.omk1980 wrote: Sat May 14, 2022 3:08 am
but it is not activated unless the registry key is there. so if you deleted it your ok.
omk1980
Oh. Awesome. Thanks for confirming.
