Pitch Black German 4K UHD
Rodney M
Send tgz file.
Danke
Danke
Boogie2005
Re: Pitch Black German 4K UHD
Is there a solution to rip this UHD BD?
As per the UHD FAQ, Rodney M did the right thing and emailed the dump. When it is decrypted MakeMKV will download the key. You should email your dump too, since it might be different.
Boogie2005
OK, but where is the mail? I can't find it.
Boogie2005
I find the mail !
Boogie2005
How long do I have to wait until it works again? I sent the mail with my tgz yesterday.
Just below the email address in the FAQ is the section:Boogie2005 wrote: Fri May 13, 2022 1:43 pm How long do I have to wait until it works again? I sent the mail with my tgz yesterday.
I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer....
The FAQ is your friend...
Rodney M
Unfortunately it still doesn't work, should I send the tgz file again?
Chetwood
According to the FAQ you should wait...
Boogie2005
I have now sent a second mail. What does the email have to say? And how can I tell if makemkv is fetching an update? I use version 1.16.7.
Boogie2005
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29396092
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29395172
Das Öffnen der Disk schlug fehl
I still get that reported. Do I have to wait until there is an update for the programme?
Arndrell
Same issue, dump email
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Arndrell
Now ripped, thank you
Harry 4k
i have se,for pitch black.nt email with dump file
