Cant rip DUNE 2021 - SOLVED
twitch
Post by twitch »
Hi Guys, i had a similar problem with Monster Hunter a while ago.
It just stops ripping after a while...
Any Ideas?
I tried my Drive internally SATA and externally via USB -> same result
Is my drive broken? I ripped like 30 or more UHDs with close to no issues...
Saving 1 titles into directory //ds220/Movies/movies/Dune
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '11324160000'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '11324160000'
Failed to save title 0 to file //ds220/Movies/movies/Dune/Dune_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Cant rip DUNE 2021
the usual advice
clean the disc
replace the disc
clean the drive
replace drive with BU40N/BP60NB10/Pioneer
generally an ASUS stopping with the infinitely increasing time in the rip is a bad sign
twitch
Post by twitch »
Disc is cleaned...
How to clean the drive properly?
Just ripped Taxi Driver Bluray wo issues...
Yes i might try the BU40N as next...
twitch wrote: Wed May 11, 2022 10:25 am Disc is cleaned...
eject tray
pop front off side clips
flip upside down 4 screws
commonsense from there
clean the lasers with some alcohol and buff dry so no streaks
i have better instructions somewhere if you want to search my posts
twitch
Post by twitch »
I will try that thank you
anyway this is the right model?
https://www.ebay.de/itm/203532978422?ep ... SwN65g-ZFf
twitch wrote: Wed May 11, 2022 10:51 am I will try that thank you
yes but you can get them preinstalled in USB case from places like techpulse archgon buffalo
twitch
Post by twitch »
I have a solid Sata Controller and will try this one first
Which MK firmware to flash? Its kind of confusing
twitch wrote: Wed May 11, 2022 11:00 am I have a solid Sata Controller and will try this one first
all you need firmware pack cuts out all the confusion
twitch
Post by twitch »
Thank you i will try it!
twitch
Post by twitch »
BU40N - flashed with the SDF Tool
Ripped DUNE first try - so my old drive was bad - problem solved - thank you!
