twitch
Post
by twitch » Wed May 11, 2022 9:30 am
Hi Guys, i had a similar problem with Monster Hunter a while ago.
It just stops ripping after a while...
Any Ideas?
I tried my Drive internally SATA and externally via USB -> same result
Is my drive broken? I ripped like 30 or more UHDs with close to no issues...
Saving 1 titles into directory //ds220/Movies/movies/Dune
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '11324160000'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '11324160000'
Failed to save title 0 to file //ds220/Movies/movies/Dune/Dune_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
- 2.PNG (63.24 KiB) Viewed 13526 times
- Over.PNG (79.9 KiB) Viewed 13526 times
twitch on Mon May 16, 2022 5:20 pm, edited 1 time in total.
Post
by Billycar11 » Wed May 11, 2022 10:09 am
the usual advice
clean the disc
replace the disc
clean the drive
replace drive with BU40N/BP60NB10/Pioneer
generally an ASUS stopping with the infinitely increasing time in the rip is a bad sign
twitch
Post
by twitch » Wed May 11, 2022 10:25 am
Disc is cleaned...
How to clean the drive properly?
Just ripped Taxi Driver Bluray wo issues...
Yes i might try the BU40N as next...
Post
by Billycar11 » Wed May 11, 2022 10:49 am
twitch wrote: Wed May 11, 2022 10:25 am
Disc is cleaned...
eject tray
pop front off side clips
flip upside down 4 screws
commonsense from there
clean the lasers with some alcohol and buff dry so no streaks
i have better instructions somewhere if you want to search my posts
Post
by Billycar11 » Wed May 11, 2022 10:54 am
yes but you can get them preinstalled in USB case from places like techpulse archgon buffalo
twitch
Post
by twitch » Wed May 11, 2022 11:00 am
I have a solid Sata Controller and will try this one first
Which MK firmware to flash? Its kind of confusing
- Bild_2022-05-11_130024176.png (4.26 KiB) Viewed 13508 times
Post
by Billycar11 » Wed May 11, 2022 11:11 am
twitch wrote: Wed May 11, 2022 11:00 am
all you need firmware pack cuts out all the confusion
twitch
Post
by twitch » Wed May 11, 2022 11:38 am
Thank you i will try it!
twitch
Post
by twitch » Mon May 16, 2022 5:20 pm
BU40N - flashed with the SDF Tool
Ripped DUNE first try - so my old drive was bad - problem solved - thank you!
