Godfather II & III issues
Re: Godfather II & III issues
Post by SamuriHL » Wed Mar 30, 2022 2:58 pm
BDR-212UBK. Don't know if that's the "best" Pioneer drive but it works very well for me. It's slow...4x max for UHD. I think that's part of its charm, however, when it comes to these stupid problematic discs. I read all 3 of my Godfather discs with that drive and had zero problems.
Post by dcoke22 » Wed Mar 30, 2022 3:48 pm
I also have a Pioneer BDR-212UBK drive which has been working well.
UHDRips
Post by UHDRips » Wed Mar 30, 2022 7:40 pm
dcoke22 wrote: Wed Mar 30, 2022 3:48 pm I also have a Pioneer BDR-212UBK drive which has been working well.
SamuriHL wrote: Wed Mar 30, 2022 2:58 pm BDR-212UBK. Don't know if that's the "best" Pioneer drive but it works very well for me. It's slow...4x max for UHD. I think that's part of its charm, however, when it comes to these stupid problematic discs. I read all 3 of my Godfather discs with that drive and had zero problems.
Thank you dcoke22 and SamuriHL
omk1980
Post by omk1980 » Thu Apr 07, 2022 8:09 pm
SamuriHL wrote: Tue Mar 29, 2022 12:06 pm It's set using registry entries so if you didn't explicitly set it, then it's disabled.
As for drives I only recommend bu40n or pioneer drives these days. Pioneer are slower but read very well. The bu40n is like a tank. It reads everything I've thrown at it except physically damaged discs.
Do you think the bu40n or any troubleshooting would get passed a scratch like this on my godfather 2 disk?
https://imgur.com/a/tMswk0A
Post by SamuriHL » Fri Apr 08, 2022 12:11 am
Physically scratched discs are almost always unrecoverable. Doesn't matter what drive you use. The data is so packed on these discs that a scratch renders it pretty useless most of the time.
omk1980
Post by omk1980 » Fri Apr 08, 2022 12:33 am
SamuriHL wrote: Fri Apr 08, 2022 12:11 am Physically scratched discs are almost always unrecoverable. Doesn't matter what drive you use. The data is so packed on these discs that a scratch renders it pretty useless most of the time.
Yeah, my wh16ns60 has been great thus far. Hopefully the replacement is better.
omk1980
Post by omk1980 » Sun Apr 17, 2022 6:19 am
Was able to get a replacement disc and was able to backup w/o issue. Thanks everyone for their help.
omk1980
Post by omk1980 » Wed May 11, 2022 3:37 am
SamuriHL wrote: Tue Mar 29, 2022 12:41 pm Read this:
viewtopic.php?f=19&t=22689
looked like that godfather disc was scratched. was able to rip a copy. is keeping the read speed unlimited going to introduce errors in ripping w/the wh16ns60? right now the value is set to 0, not 0=99, but when i open up makemkv, unrestricted read speed is listed as "yes". What do i change the registry value to if i want to go back to the default?
Post by SamuriHL » Wed May 11, 2022 9:12 pm
Delete the registry entry if you want to default it. That's the easiest way.
omk1980
Post by omk1980 » Wed May 11, 2022 9:44 pm
so in windows, in registry editor, delete the "speed_HL-DT-ST...." file? will it recreate a new file when makemkv starts back up?
Post by SamuriHL » Thu May 12, 2022 2:22 am
Just delete the data in that string. You don't have to delete the key itself. Just make the value blank.
omk1980
Post by omk1980 » Sat May 14, 2022 3:06 am
SamuriHL wrote: Thu May 12, 2022 2:22 am Just delete the data in that string. You don't have to delete the key itself. Just make the value blank.
Weird. I did that and it still shows unrestricted read access. I also uninstalled makemkv, deleted the makemkv registry files and reinstalled and it's still there. I guess it'll always be on. Hope it doesn't lead to more read errors.
Post by SamuriHL » Sat May 14, 2022 1:33 pm
As you saw in the other thread it'll always tell you the capability is there but it's not activated if the key isn't set.
omk1980
Post by omk1980 » Sat May 14, 2022 2:34 pm
Thanks for the reply.
