LG BP50NB40
mmcg1903
LG BP50NB40
Post by mmcg1903 » Wed Apr 06, 2022 1:08 pm
I have an LG BP50NB40 which I have been using to great success using MKV to archive my Blu-Ray collection to a NAS drive in my home. I now like to do the same with my growing 4k Blu-ray discs. I would like to know if it's possible with my drive and if so where can I download the SDFtool flasher and which file is best for my device?
Any help would be much appreciated.
Here are the drive specs from MKV
Product: BD-RE BP50NB40
Revision: 1.01
Serial number:
Firmware date: 2117-11-23 16:15
Highest AACS version: 31
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Re: LG BP50NB40
Post by dcoke22 » Wed Apr 06, 2022 5:49 pm
Ultimate UHD Drives Flashing Guide Updated 2022
That post has the list of drives, links to tools and firmware, recommendations for firmware levels… everything you need.
mmcg1903
Re: LG BP50NB40
Post by mmcg1903 » Thu Apr 07, 2022 10:08 am
Thanks for the reply mate, am I correct in saying I need to purchase the SDFtool Flasher?
Also I'm running windows 11 is this an issue?
Re: LG BP50NB40
Post by Billycar11 » Thu Apr 07, 2022 11:04 am
mmcg1903 wrote: Thu Apr 07, 2022 10:08 am Thanks for the reply mate, am I correct in saying I need to purchase the SDFtool Flasher?
no
and
no
its free unless you want an automated flasher from me or Marty
mmcg1903
Re: LG BP50NB40
Post by mmcg1903 » Thu Apr 07, 2022 12:11 pm
Cheers for the reply mate, must be just me but I can't see the link to download the tool flasher?
Re: LG BP50NB40
Post by Billycar11 » Thu Apr 07, 2022 12:49 pm
mmcg1903 wrote: Thu Apr 07, 2022 12:11 pm Cheers for the reply mate, must be just me but I can't see the link to download the tool flasher?
It's built in to makemkv
The GUI community addon by marty is linked under the drive Unlocked Flashers, Downgrade Enabled Firmware and MK Firmware: section
baishen
Re: LG BP50NB40
Post by baishen » Wed May 11, 2022 12:04 am
I'm attempting to flash my drive using the SDFTool and I'm running into some issues. There's no BP50NB40 firmware in the DE pack and there's only one fBP50NB40 firmware in the MK pack. The flasher thread linked earlier says this about the drive.
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 1.03-MK.
2. Flash the drive again to BP50NB40 1.03-MK, this time checking the "bootloader" box.
Is the HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin firmware in the MK pack the 1.03-MK mentioned above? What is the SVC: NB52?
When I try and flash my drive with the MK firmware I get an error message. This post seems to imply that I should be using the BP60NB10 firmware. I assume that means the HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin in the MK pack. However, this doesn't seem to be mentioned anywhere but the one post buried in the thread.
viewtopic.php?f=16&t=22896&p=121153&hil ... 40#p121153
And this post seems to imply that I should be using BU40N firmware.
viewtopic.php?f=16&t=27778&p=121077&hil ... 40#p121077
Can someone point me in the right direction?
Thanks.
Re: LG BP50NB40
Post by Billycar11 » Wed May 11, 2022 12:10 am
baishen wrote: Wed May 11, 2022 12:04 am I'm attempting to flash my drive using the SDFTool and I'm running into some issues. There's no BP50NB40 firmware in the DE pack and there's only one fBP50NB40 firmware in the MK pack. The flasher thread linked earlier says this about the drive.
Thanks.
look at your svc on the bottom if its nb52 do the nb52 steps
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty
link in guide
baishen
Re: LG BP50NB40
Post by baishen » Wed May 11, 2022 10:46 am
Mine says NB50.
Re: LG BP50NB40
Post by Billycar11 » Wed May 11, 2022 10:53 am
baishen wrote: Wed May 11, 2022 10:46 am Mine says NB50.
then follow the standard steps
and tell us the error you get
baishen
Re: LG BP50NB40
Post by baishen » Wed May 11, 2022 11:02 am
To clarify, the standard steps are to just flash it with HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin?
I just tried that and didn't get an error, but I remembered I had left a disc in the drive and removed that first. Not sure if that's what was causing the error previously.
Either that's not the right process or I did something wrong as it's not recognizing my 4k discs.
OS device name: /dev/sr1
Revision: 1.03
Serial number: XXX
Highest AACS version: 76
Firmware version: 1.03
Re: LG BP50NB40
Post by Billycar11 » Wed May 11, 2022 11:10 am
baishen wrote: Wed May 11, 2022 11:02 am To clarify, the standard steps are to just flash it with HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin?
Revision: 1.03
Serial number: XXX
the guide exists for a reason read it.
if you dont want to read it, get the automated flashing service from me or Marty where everything is done automatically
baishen
Re: LG BP50NB40
Post by baishen » Wed May 11, 2022 11:19 am
I did read the guide and the SDF tool. The relevant details are just a bit scattered across all of that.
The step I was missing was this.
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
It seems to be working correctly now, but it'll be a while before the rip completes and I know for sure.
Thanks.
baishen
Re: LG BP50NB40
Post by baishen » Wed Jun 08, 2022 4:39 pm
Billycar11 wrote: Wed May 11, 2022 12:10 am look at your svc on the bottom if its nb52 do the nb52 steps
link in guide
I successfully flashed my nb50 drive and ended up picking up a second drive for a backup. However, this drive is nb52. I did the first two steps mentioned, but now I can't get the drive to flash anything else. It appears to be stuck at BP50NB40-NB50-1.03MK. I've tried both of the firmware in Marty's link and neither one seems to do anything. The flasher always says that it completes successfully.
NM, I found the step I was missing.
3. Select the RECOVERY option and in the pop up, select the BP50NB40 1.03-MK firmware that you just flashed.
4. Select the BP60NB10 1.00-MK firmware in the normal drop box.
5. Click START
ihopnavajo2
Re: LG BP50NB40
Post by ihopnavajo2 » Thu Sep 05, 2024 2:37 pm
baishen wrote: Wed Jun 08, 2022 4:39 pm
link in guide
5. Click START
Thanks! I was having issues and I guess I missed that same part as well. Glad you put this thread together.
