Pioneer BDR-213JBK
Pioneer BDR-213JBK
I have purchased this new ultra hd bluray drive from Amazon . Need guidance about its performace regarding ripping .
I wonder if it is capable of burning 100gb UHD and if they are then seen by the Sony UBP-X800M2 player
thanks
thanks
Re: Pioneer BDR-213JBK
No don't burn disc copy's put them on a HDD
good, but do you think I made a good purchase? is it capable of burning bd 100 which are then read by my blu ray player?
Pioneer optical drives have the best reputation for burning. So, if any drive could successfully burn a 100GB optical disc, the Pioneer could.
Your Sony player, the x800m2, has a reputation as being a very capable player. It probably isn't necessary to burn discs to play movies on it. Putting proper rips on a USB hard drive should be enough.
The BDR-213JBK seems to be a new Japan only model. Does MakeMKV allow you to rip a UHD with it?
It capable of doing it but depending how you do it it may or may not playback in the bluray player
I have yet to receive, I expect to have it within 10 days so I will do some tests and write here to share it.dcoke22 wrote: ↑Wed May 11, 2022 6:25 pmPioneer optical drives have the best reputation for burning. So, if any drive could successfully burn a 100GB optical disc, the Pioneer could.
I'm interested in getting one of these drives as well, have you received yours yet? Does it work well for you?Mikele74 wrote: ↑Wed May 11, 2022 6:41 pmI have yet to receive, I expect to have it within 10 days so I will do some tests and write here to share it.dcoke22 wrote: ↑Wed May 11, 2022 6:25 pmPioneer optical drives have the best reputation for burning. So, if any drive could successfully burn a 100GB optical disc, the Pioneer could.
yes, received and that's fine hasn't burned a BD-R but I haven't tried to rip yet as it's not an operation I do. But to burn BDs that's fine!
Are there any news/infos when the 213 series drives will be available in Europe? It's weird that there doesn't seem to be anything at all yet, like if there'll be 213E/M or 213D drives without UHD compatibility.
