skutah
#1201 Post by skutah » Sun May 08, 2022 10:41 pm
Any ideas anyone?
#1202 Post by MartyMcNuts » Mon May 09, 2022 12:21 am
skutah wrote: Sun May 08, 2022 10:41 pm Any ideas anyone?
Yep, use windows 10.
weust
#1203 Post by weust » Mon May 09, 2022 9:54 am
weust wrote: Fri May 06, 2022 11:36 am I got my LG WH16NS60 in yesterday.
Manufacturing date of 23 December 2021.
Of course it came with firmware version 1.03
Just flashed it and it shows the following:
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: M00LCOG5159
Highest AACS version: 76
Firmware version: 1.02
I did the flashing using a SATA cable, because when I first had the drive in my OWC Mercury Pro external case it was not detected.
I *think* it saw the USB chipset or something, because with an audio CD it would detect a 388MB drive.
The case has been working fine for several years now with a flashed Asus BW-16D1HT.
Putting the drive in there after this post and see what happens then.
Kinda weird, but glad the drive is fine because it came from the USA to NL because the drive here in over twice as expensive.
Small update. OWC support was pointless. No help at all.
I did find out that if I power on the drive/enclosure with the USB cable plugged in it fails to see the drive.
But when I then unplug and plug the cable back in, the drive is seen.
Same goes for when I don't have the cable plugged in and turn the drive on and then plug the cable in.
Something odd going on, but other then that it seems to work. For now.
skutah
#1204 Post by skutah » Wed May 11, 2022 1:36 pm
MartyMcNuts wrote: Mon May 09, 2022 12:21 am
So very helpful.
Thanks, but no thanks.
Anyone else? Can't be the only person here who uses MakeMKV on Linux?
#1205 Post by dcoke22 » Wed May 11, 2022 8:38 pm
skutah wrote: Sun May 01, 2022 9:07 pm 3. Entered: ./makemkvcon f -l and got this:
00: dev_21:7, /dev/sr1, /dev/sr1
HL-DT-ST_BD-RE_BP50NB40_1.01_211711231615_SIKBCIABN1311
4. Then entered: ./makemkvcon f -d '/dev_21:7' -f /home/path-to-file/sdf.bin rawflash main -i /home/path-to-file/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Got this: Drive "/dev_21:7" not found
I don't use MakeMKV on Linux… but the result of command 3 was:
but in your command 4 you changed dev_21:7 to /dev_21:7. Maybe try it without the leading slash.
Or try substituting /dev/sr1 into your command.
hankZ
#1206 Post by hankZ » Thu May 12, 2022 3:30 am
My old drive has stopped working; it's giving me the no disc error. What's the most reliable drive I should get? The LG BU40N or the LG WH14NS40?
If there's a better drive let me know. My budget is $90.
skutah
#1207 Post by skutah » Fri May 13, 2022 9:43 pm
dcoke22 wrote: Wed May 11, 2022 8:38 pm
Thank you very much! That actually was what created the error!
I had overlooked that the slash in the example had been taken from the output of command 3 and missing in the output on my machine.
It still gives me a "no disc" error, so I have to look for a solution for this new issue now but it definitely said the flashing process was successful and my original error is gone.
Thanks again, much appreciated.
jonghotti
#1208 Post by jonghotti » Sat May 14, 2022 7:32 am
I need my name added back to the sellers list please.
hankZ
#1209 Post by hankZ » Sat May 14, 2022 8:45 am
Thank you for this guide! It worked like a charm!
sapphire
#1210 Post by sapphire » Tue May 17, 2022 8:01 pm
I accidently flashed a Desktop to a Slim Drive. What do I do know? I've been trying to restore it to the way it was before for hours now, but with no success. Can anyone kindly help me please?
My Drive name is LG WH16NS40.
(My original intent was to downgrade my firmware, which was at 1.05 because my Blu-ray drive did not want to read my new Blu-ray discs that I bought at all, but I could easily rip them through Make MKV Software).
Thank you!
Sapphire.
louiethe14th
#1211 Post by louiethe14th » Wed May 18, 2022 1:23 am
To flash a drive with encrypted firmware on Linux (or Mac), I was required to replace 'main'
"./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/your firmware filename here
with 'enc' instead. Thanks to SanDiegoDana for pointing this out (earlier in this thread).
weust
#1212 Post by weust » Wed May 18, 2022 3:02 pm
Just a generic question, are the firmware files specific for use with MakeMKV?
I flashed my LG WH16NS60 and it works fine with MakeMKV, but DVDFab Passkey complains the drive is not usable.
My ASUS BW-16D1HT works fine with both, but it's been so long since I flashed it I just can't remember if I used this forum for it or another one.
#1213 Post by Billycar11 » Wed May 18, 2022 3:38 pm
weust wrote: Wed May 18, 2022 3:02 pm Just a generic question, are the firmware files specific for use with MakeMKV?
Go to 1.00 for dvdfab WH16NS60 is in the de pack
#1214 Post by MartyMcNuts » Wed May 18, 2022 11:48 pm
sapphire wrote: Tue May 17, 2022 8:01 pm Hello,
Thank you!
Sapphire.
If this is a new(ish) WH16NS40 (SVC: NS50) that came with 1.05, then you can use the recovery option in SDFtool Flasher.
Simply select the incorrect current firmware that is on the drive in the popup, then select the correct firmware to flash to the drive (recommend WH16NS60 1.02-MK).
weust
#1215 Post by weust » Thu May 19, 2022 9:35 am
Billycar11 wrote: Wed May 18, 2022 3:38 pm
Excellent. Thank you very much.
