I have a LG BP60NB10 drive and trying to convert The Piano and am having trouble.
Status before flash:
BD-RE BP60NB10
OS device name: \Device\CdRom3
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03KA881953
Firmware date: 2121-07-08 15:56
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
After flash:
Revision: 1.02
Firmware date: 2120-05-07 09:35
Disc Information
Label: THE_PIANO
Timestamp: 2021-11-22 16:16:37
Protection: AACS2.0/C v76
Data capacity: 79.83 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Have gotten a big variety of errors before/after a reboot, how or when I start makeMKV, when I plug in the drive - any ideas?
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '0'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '0'
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00295.m2ts' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
LG BP60NB10 Flashed and still doesn't Work
Re: LG BP60NB10 Flashed and still doesn't Work
It's not getting enough power and is rebooting
Thank you so much. How were you able to determine the problem from the errors. Must have a lot of experience with this stuff. Thanks again - thought there was no way it was going to work. I moved it to my Mac Mini. The usb hub most have more power.
It'll only work on a USB hub that has it's own power supply, not powered by a USB port.wleduc wrote: Sun May 08, 2022 10:36 pm Thank you so much. How were you able to determine the problem from the errors. Must have a lot of experience with this stuff. Thanks again - thought there was no way it was going to work. I moved it to my Mac Mini. The usb hub most have more power.
Man, so frustrating. This drive was working just fine a few months back when I was pulling stuff. I'm not sure when or why it needed some kind of upgrade, but I used the updated flash tool and now I'm getting a 'HashCheck Error'. Any help or workarounds to get this working again would be appreciated on the LG Slim BP60NB10.
Clean the disc
