LG BP60NB10 Flashed and still doesn't Work
wleduc
Post by wleduc » Sat May 07, 2022 11:31 pm
I have a LG BP60NB10 drive and trying to convert The Piano and am having trouble.
Status before flash:
BD-RE BP60NB10
OS device name: \Device\CdRom3
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03KA881953
Firmware date: 2121-07-08 15:56
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
After flash:
Revision: 1.02
Firmware date: 2120-05-07 09:35
Disc Information
Label: THE_PIANO
Timestamp: 2021-11-22 16:16:37
Protection: AACS2.0/C v76
Data capacity: 79.83 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Have gotten a big variety of errors before/after a reboot, how or when I start makeMKV, when I plug in the drive - any ideas?
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00305.m2ts' at offset '0'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '0'
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00295.m2ts' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Re: LG BP60NB10 Flashed and still doesn't Work
Post by Billycar11 » Sun May 08, 2022 7:14 am
It's not getting enough power and is rebooting
wleduc
Post by wleduc » Sun May 08, 2022 10:36 pm
Thank you so much. How were you able to determine the problem from the errors. Must have a lot of experience with this stuff. Thanks again - thought there was no way it was going to work. I moved it to my Mac Mini. The usb hub most have more power.
Post by MartyMcNuts » Mon May 09, 2022 12:20 am
wleduc wrote: Sun May 08, 2022 10:36 pm Thank you so much. How were you able to determine the problem from the errors. Must have a lot of experience with this stuff. Thanks again - thought there was no way it was going to work. I moved it to my Mac Mini. The usb hub most have more power.
It'll only work on a USB hub that has it's own power supply, not powered by a USB port.
adamin3D
Post by adamin3D » Sat Jun 11, 2022 8:02 pm
Man, so frustrating. This drive was working just fine a few months back when I was pulling stuff. I'm not sure when or why it needed some kind of upgrade, but I used the updated flash tool and now I'm getting a 'HashCheck Error'. Any help or workarounds to get this working again would be appreciated on the LG Slim BP60NB10.
Post by Billycar11 » Sun Jun 12, 2022 8:11 am
Clean the disc
