Attempting to flash in macOS
librarian
Re: Attempting to flash in macOS
Post by librarian » Sun May 08, 2022 7:31 pm
I'm about to flash my new Archgon. Any advice about what BU40N version I should flash to? I'm on 1.02 right now; should I aim for HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin? I'll be flashing with macOS, so any advice for the commands to use would be helpful.
Here's my info:
Product: BD-RE BU40N
Revision: 1.02
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
ghalepa
Post by ghalepa » Tue May 10, 2022 4:20 am
I have gone through the terminal process trying to flash the firmware on the Archgon and gotten all the way to the end, with it telling me 100% Operation finished Done Successfully. Yet, when I launch MakeMKV the drive still shows the original firmware and cannot rip UHD discs. I am incredibly puzzled.
I am in the same situation with a BU40N in an Archgon case - my MakeMKV info is as follows:
Revision: 1.02
Serial number: MO1LC2F3441
Highest AACS version: 76
Any suggestions would be appreciated.
librarian
Post by librarian » Tue May 10, 2022 4:31 am
ghalepa wrote: Tue May 10, 2022 4:20 am I am in the same situation with a BU40N in an Archgon case - my MakeMKV info is as follows:
/snip
I installed Windows 10 LTSC with Boot Camp on my Mac and flashed with the normal methods. Wasn’t as fast as the command line would have been, but I knew it would work. Seems to have.
Product: BD-RE BU4ON
Revision: 1.03
Serial number:
Firmware version: 1.03
Post by Billycar11 » Tue May 10, 2022 4:31 am
Revision: 1.02
post your terminal input and output
ghalepa
Post by ghalepa » Tue May 10, 2022 5:18 am
Billycar11 wrote: Tue May 10, 2022 4:31 am
Revision: 1.02
When I attempted the flash:
Jurgen:MacOS greghale$ ./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/D3244179
HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1LC2F3441
Jurgen:MacOS greghale$ ./makemkvcon f -d '/IOBDServices/D3244179' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1LC2F3441
yes
Done successfully
Now, when I try to show the drive identifier:
Jurgen:MacOS greghale$ cd /Applications/MakeMKV.app/Contents/MacOS
Found 1 drives(s)
Post by Billycar11 » Tue May 10, 2022 5:24 am
ghalepa wrote: Tue May 10, 2022 5:18 am
Found 1 drives(s)
yes
Done successfully
Found 1 drives(s)
replace main with enc you need to pay more attention to the guide
ghalepa
Post by ghalepa » Tue May 10, 2022 5:32 am
Of course, you are correct. My apologies for not figuring it out. I do appreciate your help though and thank you for your efforts for the community.
librarian
Post by librarian » Tue May 10, 2022 5:33 am
I guarantee that’s the issue. I had errors with the GUI tool because I thought I had to flash to the downgrade enabled DE firmware for my drive, but that was not required. I just flashed directly to the HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 with the default enc option in the GUI tool, and it worked. I power cycled just to be sure it was initialized and the software detected LibreDrive immediately. Hope that helps.
ThatGuyName
Post by ThatGuyName » Tue Aug 08, 2023 5:55 pm
Do you need to unzip the firmware pack first? Terminal is giving me an Input file not found error.
Post by dcoke22 » Wed Aug 16, 2023 6:13 am
ThatGuyName wrote: Tue Aug 08, 2023 5:55 pm Do you need to unzip the firmware pack first? Terminal is giving me an Input file not found error.
Yes.
eMouse
Post by eMouse » Wed Mar 06, 2024 7:15 pm
I'm attempting to flash a BP60NB10 on MacOS.
When I run '/Applications/MakeMKV.app/Contents/MacOS/sdftool -l' I get the following response:
Found 1 drives(s)
00:
HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIM03L33E2224
Note, no "/IODBServices/[identifier]" after the 00: or before the drive name.
When I put in a regular BR disk and use MakeMKV, it changes to
Found 1 drives(s)
00: /dev/rdisk16, /dev/rdisk16
But still no "/IODBServices" identifier. I tried using the /dev/rdisk16 as the disk identifier, but it refused to flash because there was a disk in the drive. As soon as I removed the disk, it went back to just being '00:'.
Is there something I'm doing wrong here? It doesn't seem like anyone else has reported having this issue.
Post by dcoke22 » Wed Mar 06, 2024 8:05 pm
eMouse wrote: Wed Mar 06, 2024 7:15 pm I'm attempting to flash a BP60NB10 on MacOS.
What version of MacOS are you running?
eMouse
Post by eMouse » Wed Mar 06, 2024 8:14 pm
dcoke22 wrote: Wed Mar 06, 2024 8:05 pm What version of MacOS are you running?
Sonoma 14.2.1 (23C71)
Post by dcoke22 » Wed Mar 06, 2024 8:37 pm
I don't have any Macs running Sonoma. I have Macs on Monterey and Ventura (and Mojave). This works for me on both Monterey and Ventura.
I do know that the latest version of Sonoma is 14.3.1. You could try to update your Mac to the latest. Or wait to see if someone else running Sonoma replies.
I suppose it worth verifying that you're running a recent version of MakeMKV, right?
Is your optical drive plugged directly into your Mac?
eMouse
Post by eMouse » Wed Mar 06, 2024 10:42 pm
I'll run the latest OS update and see if it changes anything.
I had to re-download MakeMKV, so it is the latest version of that.
The drive is plugged into a USB hub, which is then plugged into the Mac. It's a Mac mini, and the drive requires two USB ports, so plugging it directly into the Mac isn't really an option.
If necessary, I can connect the drive to a windows machine, but this Mac is what I use 90% of the time.
