ArArdin
Post by ArArdin »
Mattl0 wrote:
Thu May 05, 2022 9:26 am
Here you go https://mega.nz/folder/fo8yHCKa#BMc78ichXyiEB1OKyqA0lw
Would you happen to know if this FW is for Ugoos AM6-b only?
I still have a neglected AM6 Plus with dualboot CoreElec stashed away somewhere.
mtotheb
Post by mtotheb »
quietvoid wrote:
Wed May 04, 2022 8:56 pm
It should probably be compared to the FEL disc, in the hope that they're the same.
I don’t have the tools to compare the FEL disc to the Version thats being sold here, but the distributer responded to my email saying the A24 Disc‘s DolbyVision is just "upscaled" to FEL while they wanted to do it in the most "native" way as the Content they received. I wonder why they didn’t go with MEL P7 then but maybe the new way going forward is doing it in P8 now?
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
quietvoid
Post by quietvoid »
Not sure but it still sounds like an oddity.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Wed May 04, 2022 4:26 pm
it says that on the original M2TS file on the bluray disc?
The m2ts doesn't have the Dolby Vision descriptor, so MakeMKV probably gets the info from probing the HEVC RPUs.
The Koch Media release doesn't seem right to me. The levels and L1 metadata are pretty different.
It's true that the A24 FEL doesn't make much difference, though.
Also, A24 has 3 trim passes (100, 600, 1000) while Koch Media only has one for 100 nits, and it's almost useless (max 2050 adjustment, where 2048 is no adjustment).
So I don't know what they're on about but the two aren't going to be the same at all in Dolby Vision playback.
Some funny thing is that the HDR10 is encoded with this:
Maximum Content Light Level : 420 cd/m2
Maximum Frame-Average Light Level : 69 cd/m2
Seems like a mess of an authoring job here, or a joke. The L1 is consistently over 600 nits, with a 1477 nits peak.
Koch Media also has L5 set to zero, when there are letterbox bars.
great analysis as usual @quietvoid ... I need to try to understand your vs-nlq script (assuming that's what you used to check FEL)...
andy22
Post by andy22 »
@RESET_9999 Hi quick question, so using your scripts its not possible to convert DV P8/7 to P5? Is that because of the different colorspace?
thanks
Mattl0
Post by Mattl0 »
ArArdin wrote:
Thu May 05, 2022 9:54 am
Your am6 plus will work with that fw : )>
ArArdin
Post by ArArdin »
Mattl0 wrote:
Fri May 06, 2022 11:07 pm
Thanks, Mattl0 :)
mtotheb
Post by mtotheb »
RESET_9999 wrote:
Fri May 06, 2022 2:47 pm
Couldn’t have said it better. @quietvoid doing gods work over here :lol:
quietvoid
Post by quietvoid »
It seems the Koch Media Lamb release might not play in Dolby Vision normally: https://github.com/justdan96/tsMuxer/is ... 1120210769
andy22 wrote:
Fri May 06, 2022 9:55 pm
thanks
Well, you can force any DV profile (wrong one included) with the mp4muxer modes.
Godmax
Post by Godmax »
How to add black bars to mkv/m2ts dolby vision video files without losing quality?
Gatorman
Post by Gatorman »
Godmax wrote:
Sat May 07, 2022 8:44 pm
I don't believe there is a way to simply add black bars to an existing file. You would need to encode the file with the correct padding values. Then make sure to edit the DV L5 metadata to account for the black bars. There is always the potential for quality loss from encoding a file already encoded from a full rip.
More reasons to collect physical media. Ugoos AM6B+.
kazuma
Post by kazuma »
so the best udh player voor dolby vision mp4 is the sony ubp-x700? which one you guys recommended? or the LG UBK90?
andy22
Post by andy22 »
@RESET_9999
Just a test to convert HDR10+ to DV
I cant get the scripts (1.26) to work, at the end there are always
(os error 2)
errors any tips? I did set a custom output path and it creates /Temp folder with files in it correctly, but than always breaks with those errors?
Drag and drop your HDR10plus MKV/MP4/TS file and press enter...Z:\Downloads\Dolby-Vision-Tools\test.mkv
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped and DV isnt) and press enter...
Measuring the HDR10 video letterbox...
min: 0.0001 cd/m2, max: 1000 cd/m2
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'z:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Extracting HDR10plus...
Reading parsed dynamic metadata... Done.
Reordering metadata... Done.
Generating and writing metadata to JSON file... Done.
Parsing HDR10+ JSON file...
Generating metadata...
Generated metadata for 57044 frames
Done.
Error: expected value at line 4 column 16
EditConfig {
    mode: 0,
    convert_to_cmv4: false,
    remove_mapping: false,
    active_area: None,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: Some(
        ExtMetadataBlockLevel6 {
            max_display_mastering_luminance: 1000,
            min_display_mastering_luminance: 1,
            max_content_light_level: 0,
            max_frame_average_light_level: 0,
    level9: None,
    level11: None,
Parsing RPU file...
Error: The system cannot find the file specified. (os error 2)
MDL.max: 1000
MDL.min: 1
Maxcll: 0
Maxfall: 0
injecting RPU-L6-L5.bin ...
Parsing RPU file...
Parsing RPU file...
The process cannot access the file because it is being used by another process.
"The script has completed."
