Pioneer BDR-XD07UHD
boolian2
Pioneer BDR-XD07UHD
Post by boolian2 » Fri May 06, 2022 12:12 am
Does Pioneer BDR-XD07UHD work with MakeMKV and DVDFab out of the box? Does MakeMKV need to be installed for it to work? Thanks
Re: Pioneer BDR-XD07UHD
Post by MartyMcNuts » Fri May 06, 2022 12:40 am
boolian2 wrote: Fri May 06, 2022 12:12 am Does Pioneer BDR-XD07UHD work with MakeMKV and DVDFab out of the box? Does MakeMKV need to be installed for it to work? Thanks
It should work for all disc types with MakeMKV out of the box provided the drive model and firmware version are in this list: viewtopic.php?p=118751#p118751
The drive may also work with DVDFab for HD BLU-RAY / DVD / CD only. It will not work for UHD.
boolian2
Post by boolian2 » Fri May 06, 2022 1:11 am
Why does my LG WH16Ns60 work for UHD on DVDFab but the Pioneer won't?
Post by MartyMcNuts » Fri May 06, 2022 1:47 am
boolian2 wrote: Fri May 06, 2022 1:11 am Why does my LG WH16Ns60 work for UHD on DVDFab but the Pioneer won't?
Because, as far as I can tell, DVDFab have not come up with a Pioneer UHD compatible method yet...
boolian2
Post by boolian2 » Fri May 06, 2022 2:10 am
Oh, ok thanks I understand now
