aboulfad
#6451 Post by aboulfad » Mon May 02, 2022 11:43 am
nekno wrote:
Mon May 02, 2022 7:49 am
… Since you converted the DV7 RPU to DV8.1 with dovi_tool mode 2, but then presumably set the profile to DV5 with mp4muxer, that seems to be enough to get by Infuse's new checks and trigger DV. …
Sorry I mentioned earlier I used yusesope mode 2 to create a STSL but you are correct on the latter part.
Btw I found some of my commands that created that linked mp4 but sadly never backed up that directory with all my files. I can redo what I toyed with 1.5 years ago but I think the consensus is clear on “proper” conversion/rip from UHD P7 DV to P5 for Infuse/ATV 4K DV consumption.
bl_el_rpu_builder-0.0.3.py -bl pBL.hevc -el pEL.hevc -of pBL_RPU.hevc -mode 2
mp4muxer -i pBL_RPU.hevc --dv-profile 5 -o pBL_RPU_p5.mp4
mp4box -add pBL_RPU_p5.mp4+truehd.mp4 -brand mp42isom -ab dby1 -no-iod pBL_RPU_p5_truehd.mp4
aboulfad
#6452 Post by aboulfad » Mon May 02, 2022 11:48 am
NiCE77 wrote:
Mon May 02, 2022 10:11 am
nekno wrote:
Sun May 01, 2022 7:59 pm
Only DV5 with an IPT BL and DV8.4 with an HLG BL should trigger DV playback, because those are the only profiles supported by the ATV4K.
It seems, that ATV 2021 does not use the RPU for HLG based P8.4 videos either. I checked with RESET_9999 videos.
Very interesting, so I played those files (including P5 fake/real) and I notice some periodic changes in the video stream of some of them (hue changes ?) but I couldn’t find explanation on how to interpret the usage of those test files. I did search here too, any clues/tips is greatly appreciated.
I feel really silly because I never got past the red screen in some of those files until now ... I thought the DV file was not being displayed correctly. Here's my noob observations for some of those test video files (P5/P8) using Infuse 7.3.10/ATV4K/LG E7:
1. RPU TEST SL fake p5.mp4 : dvhe.05.06, BL+RPU, BT.2020/PQ
- DV triggers, red screen, bunch of text on red/blue/red screen, scary guy staring at me
- I can't tell wether there's some scene by scene adjustment regarding to RPU
- According to recently found comment and that video display full screen, ATV 4K is not reading RPU from my created DV P5 using yusesope mode 2
2. RPU TEST SL real p5.mp4: dvhe.05.06, BL+RPU (missing meta data)
- DV triggers, some video aspects are periodically changing: brightness, hue, ... ?
- In some scenes I do notice the lights (specular highlights ?) are kinda bright.
3. RPU TEST SL p8.mp4: dvhe.08.06, BL+RPU, BT.2020/PQ
- same as (1) above
4. HLG DV P8 in sync.mp4: dvhe.08.07, BL+RPU, BT.2020/HLG
- can't tell much
manuelrn
#6453 Post by manuelrn » Mon May 02, 2022 11:59 am
quietvoid wrote:
Sun May 01, 2022 1:38 pm
manuelrn wrote:
Sun May 01, 2022 1:36 pm
And in those cases, would it be possible for dovi_tool to omit those EOS/EOB NALUs and keep only the last one? (when muxing and injecting)
That is, if dovi_tool finds any EOS/EOB NALUs it checks if it is the last frame of the video, and if it is the last frame then dovi_tool keeps EOS/EOB NALUs but if it is not the last frame then it does not write that EOS/EOB NALUs.
No, it wouldn't be able to know how many frames there are.
I'd also rather not discard anything unnecessarily.
There's indeed a bug in 1.5.0 for files with multiple EOS NALUs present.
I'll add some tests and push the fix later.
Okay, you're right.
Just to make sure, that bug is already fixed in version 1.5.1, correct?
Thank you!
Godmax
#6454 Post by Godmax » Mon May 02, 2022 1:10 pm
Is there a command with ffmpeg to add black bars to a cropped 4k Dolby Vision video file? Can be mkv or m2ts or ts doesnt matter.
#6455 Post by RESET_9999 » Mon May 02, 2022 2:06 pm
Found this 2019 comment from @reset_9999
the FEL and RPU test files can also be used to find out if your device uses the L5 active area metadata in the RPU. if it uses L5, there will be black bars otherwise it will be fullscreen.
I'm not aware of any HDMI device that uses L5 metadata the way the TV's internal player does.
I really don't understand how L5 works on HDMI devices. Seems they all ignore it and are not affected by the issue described here: viewtopic.php?p=121490#p121490
quietvoid
#6456 Post by quietvoid » Mon May 02, 2022 2:37 pm
Thank you!
Yes, see release notes: https://github.com/quietvoid/dovi_tool/ ... /tag/1.5.1
mux: Fixed repeating EOS NALUs by default. Fixes #146.
This only affected the default muxing options. If using --eos-before-el, the output file was correct.
aboulfad
#6457 Post by aboulfad » Mon May 02, 2022 2:51 pm
I am terribly sorry, I realized now I may have mis quoted your comment in my above response. My thread of questions were all related to P7 converted to DV P5 dvdhe.5.06 BL+RPU and may have confused L5 with P5 ? I still have to read/learn about RPU metadata to understand the link above. Ah DV metadata levels !!!
I am just searching in posts to learn about the video test files you made and how to interpret them on my device chain. Merci ; - )
aboulfad
#6458 Post by aboulfad » Mon May 02, 2022 8:34 pm
@nekno I re-created some DoVi mkv from my BD UHD and re-used the tools to create what I did a year ago. As you already know, yusesope tools convert P7 to P8 and mp4muxer slaps on a DoVi P5 header. It seems that is enough to fool Infuse to display DoVi so did my LG E7 internal player !!! So yeah "fake" or "frankenstein" DV P5 file for free.
As far as color space, RPU and all this stuff, I don't know what's happening. It's hard to compare with a movie without knowing the details of what is supposed to be. The test file was 10s so too short. Anyways its fun to learn all these tools (including dovi_tool), thanks to all : )
mtotheb
#6459 Post by mtotheb » Wed May 04, 2022 12:15 pm
Have you guys ever come across a Profile 8 (dvhe 08.06) in an UHD Bluray? I thought only Profile 7 was used in these but the German Release of Lamb from Koch Media surprisingly is encoded like that.
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
quietvoid
#6460 Post by quietvoid » Wed May 04, 2022 12:51 pm
I also think UHD BD is supposed to be profile 7 only.
#6461 Post by RESET_9999 » Wed May 04, 2022 1:43 pm
do you have the BDinfo report of the disc ?
mtotheb
#6462 Post by mtotheb » Wed May 04, 2022 4:07 pm
So in makemkv it says "HEVC Main10@L5.1 (dvhe.08.06 BL+RPU)" about the source.
The HEVC File is "Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible" ~ MediaInfo
But they even forgot to set the dvhe flag. I'm guessing that Bluray Players would just fallback to the HDR10 can't test it tho
I've also never seen a commercial uhd bluray being encoded with x265:
Writing library : x265 3.4+31-6722fce1f:[Mac OS X][clang 11.0.0][64 bit] 10bit
Encoding settings : cpuid=1049583 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / no-b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=1 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=60000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=80000 / vbv-bufsize=60000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1) / cll=420,69 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
#6463 Post by RESET_9999 » Wed May 04, 2022 4:26 pm
it says that on the original M2TS file on the bluray disc?
the (A24 Exclusive) bluray is FEL DV:
Disc Size: 62,679,376,060 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 1:46:27.589 (h:m:s.ms)
Total Bitrate: 70.26 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 55879 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 7688 kbps (12.09%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
mtotheb
#6464 Post by mtotheb » Wed May 04, 2022 4:34 pm
Yup that's straight off the Bluray. Great to know that the distributer here completely disregarded the FEL in probably the most unusal way for a bluray release
quietvoid
#6465 Post by quietvoid » Wed May 04, 2022 8:56 pm
It should probably be compared to the FEL disc, in the hope that they're the same.
