How to make a protected UHD ISO without Bus Encryption?
Do all the UHD Official drive has Bus Encryption? (even downgrade to 1.0 version(LG S60) or using LibreDrive)
Can I use the UHD friendly drive to make a protected UHD ISO?
Re: How to make a protected UHD ISO without Bus Encryption?
the best way would be to use makemkv and uncheck the decrypt box in the folder back up option then with that folder make an iso with imgburn other ways may not have all the needed data.ben108472 wrote: Sun May 01, 2022 4:10 am How to make a protected UHD ISO without Bus Encryption?
yes all have buss encryption
yes
I had made protected UHD ISO by ImgBurn with LG WH16NS60(flash from WH16NS58 UHD friendly drive) and decrypted it successfully with DeUHD by mounting ISO with DAEMON Tools Lite.Billycar11 wrote: Sun May 01, 2022 10:05 amthe best way would be to use makemkv and uncheck the decrypt box in the folder back up option then with that folder make an iso with imgburn other ways may not have all the needed data.ben108472 wrote: Sun May 01, 2022 4:10 am How to make a protected UHD ISO without Bus Encryption?
yes
I want to do the same way in LG WH16NS60 (UHD official drive).
I am not sure this approach is only suitable for friendly drive?
I've tried following options
UHD Official (WH16NS60)
UHD Friendly flash to UHD Official (WH16NS58 with WH16NS60 1.00 firmware)
UHD Friendly (WH16NS58)
Only UHD Friendly flash to UHD Official can produce protected UHD ISO without Bus Encryption.
This ISO can be mounted into virtual drive and can be decrypted by DeUHD.
you can do it with official drives you just have to open makemkv open the disc then use img burnben108472 wrote: Wed May 04, 2022 1:33 am I've tried following options
SamuriHL has a script for that.
SamuriHL wrote: Wed Jun 05, 2019 11:29 pm Just because I find the idea useful myself for my own workflow, I put together the script for you.
You need to change the following in this script to make it work for your system:
backup_dir make it point to where you want MakeMKV to create the decrypted folder backup
iso_dir make it point to where you want ImgBurn to create your ISO file
vol f: change f: to the drive of your optical drive you want to rip from
disc:1 change the number to the number of the drive you want to rip from (I tried dev:f: as an example and makemkvcon didn't seem to like it)
NOTE: I've not tested the ImgBurn part of this but it should work as advertised. Just copy the code block and paste it into something like backup.bat and run it and it'll create your decrypted ISO for you. Enjoy.
@echo off set backup_dir=d:\BACKUP set iso_dir=d:\ISO for /f "tokens=1-5*" %%1 in ('vol f:') do ( set vol=%%6 & goto done ) :done mkdir %backup_dir%\%vol% makemkvcon64.exe backup --decrypt --cache=16 --noscan -r --progress=-same disc:1 %backup_dir%\%vol% "C:\Program Files (x86)\ImgBurn\ImgBurn.exe" /mode build /buildmode imagefile /src "%backup_dir%\%vol%" /dest "%iso_dir%\%vol%.iso" /FILESYSTEM "UDF" /UDFREVISION "2.50" /VOLUMELABEL "%vol%" /rootfolder yes /noimagedetails /start /close pause
