SDF.bin
Claus
SDF.bin
Post by Claus » Tue Sep 15, 2020 9:35 am
Hello @all,
were can i find the actuall SDF.bin (for windows and ubuntu)to download or isn´t it necessary any more?
Thx
Claus
Re: SDF.bin
Post by Woodstock » Tue Sep 15, 2020 1:19 pm
The file itself should be automatically downloaded when you start a rip; On disk, it is added to _private_data.tar in your MakeMKV data directory.
If you want to manually download it, https://makemkv.com/sdf.bin will fetch it.
Be aware that sdf.bin does not contain the hashed keys for UHD decoding; it DOES contain the current link to it, though.
Tango
Re: SDF.bin
Post by Tango » Tue Feb 08, 2022 4:09 am
Is the version in the link kept up to date so I can be sure it's the latest one?
Re: SDF.bin
Post by dcoke22 » Tue Feb 08, 2022 6:54 am
Yes.
Tango
Re: SDF.bin
Post by Tango » Tue Feb 08, 2022 7:21 am
Thank you!
voip-ninja
Re: SDF.bin
Post by voip-ninja » Tue May 03, 2022 8:51 pm
Hey guys, sorry to resurrect this thread.
I'm having a similar problem with the automatic SDF download failing.
I've downloaded the sdf.bin into the data directory for the application (I am on MacOS Monterey) but still see this error this error when I open the application.
Am I missing a step?
Thanks.
Re: SDF.bin
Post by Billycar11 » Tue May 03, 2022 9:28 pm
Thanks.
Download privatedata.tar too it won't fix the failed download but it will get you up and running linked in below in my guide
voip-ninja
Re: SDF.bin
Post by voip-ninja » Fri May 06, 2022 12:42 pm
Thanks Billy for the info.
I perused your thread and not sure I have a good handle on why making this change might be necessary.
Preferably I would find out what the security issue is that's preventing the SDF from downloading... I use a pi-hole for DNS resolution on my internal network and also an enterprise grade firewall. Ideally I would find out what the destination IP is for downloading the files and simply white list it in all of my security areas....
Is there some other issue with MacOS now that is driving this behavior?
Re: SDF.bin
Post by Billycar11 » Fri May 06, 2022 9:07 pm
No that really does limit it to your network setup you can white list the IP but it's always changing I believe along with the URL
So
voip-ninja
Re: SDF.bin
Post by voip-ninja » Sun May 08, 2022 9:17 pm
Ah, that's unfortunate.
I think I might have more questions but as this is a very old thread I will probably just start a new one.
Thanks.
Buzzlite1926
Re: SDF.bin
Post by Buzzlite1926 » Tue Dec 12, 2023 8:25 am
Where do we download the sfd bin file for uhd?
Re: SDF.bin
Post by d00zah » Tue Dec 12, 2023 12:56 pm
Woodstock answered this in detail in post #2 of this very topic...
Buzzlite1926
Re: SDF.bin
Post by Buzzlite1926 » Tue Dec 12, 2023 9:38 pm
It's only for automatic download?
Re: SDF.bin
Post by Billycar11 » Tue Dec 12, 2023 9:40 pm
email me for the manual key download this is a 1 time thing you need to fix your problem but ill get you going
Re: SDF.bin
Post by d00zah » Tue Dec 12, 2023 10:24 pm
C'mon! Really?
