Flashing firmware on a Mac for LibreDrive
dfhsff8
Re: Flashing firmware on a Mac for LibreDrive
Post by dfhsff8 » Fri Apr 09, 2021 9:37 am
Thanks all - this worked great over here as well on a macOS Big Sur and LG BU40N with factory 1.04 model. I first flashed to 1.04MK (using the ‘enc’ option) and then to 1.03MK (without ‘enc’ option) and seems good so far.
I also took a gamble on a cheap £9 case off Amazon having been inspired by a previous poster using one from aliexpress. It worked just fine. The one I used was this 9.5mm EHZ-SHOP model: https://www.amazon.co.uk/gp/product/B077D2HS6W
sobarber
Post by sobarber » Sat Dec 25, 2021 8:43 pm
It also worked flawlessly for me on my WH16NS40 drive. :D Happy Holidays, be safe and well.
appleguy
Post by appleguy » Tue Jan 04, 2022 1:13 am
I ordered an LG BU40N from newegg.com but they sent me a HL version instead of LG. it goes through the flashing process but isn't actually applying either. it has this...
Product: BD-RE BU40N
Revision: 1.04
Serial number: **********
Firmware date: 2120-05-06 11:42
will this work with the enc option? where do I put enc in the terminal command?
thanks!
Post by Billycar11 » Tue Jan 04, 2022 1:23 am
Revision: 1.04
thanks!
Use enc see my guide
appleguy
Post by appleguy » Tue Jan 04, 2022 1:40 am
ok, so instead of ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/your firmware filename here
I used ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash enc -i /tmp/your firmware filename here
and that worked! thanks. so now it says...
Revision: 1.03
Firmware version: 1.03
so I am all set? time to try a UHD disk? thanks for all your help!
Post by Billycar11 » Tue Jan 04, 2022 1:47 am
Yeah just unplug it for a min before using it.
appleguy
Post by appleguy » Tue Jan 04, 2022 1:50 am
awesome! now to try to find a uhd disk, lol. headed out to walmart :D
Cuddy2977
Post by Cuddy2977 » Mon May 02, 2022 2:15 pm
Would flashing my blu-ray drive enable it to read 4k blu-rays?
Post by Coopervid » Mon May 02, 2022 7:14 pm
We will try to use our psychic powers to determine. However, if you would post a Makemkv status from the GUI even people without those could answer your question and give recommendations. 8)
Cuddy2977
Post by Cuddy2977 » Fri May 06, 2022 7:58 am
Right, I’ve got a Pioneer BDR-UD04: one that — in theory — can read 4k Blu-ray disks. I’ve got MakeMKV 1.16.4.
Will I be able to read 4k blu-rays, or will I need to flash the drive?
Post by Billycar11 » Fri May 06, 2022 8:15 am
yeah if you update to the latest makemkv
Cuddy2977
Post by Cuddy2977 » Tue Mar 28, 2023 7:24 pm
garygomm wrote:
Thu Sep 10, 2020 2:07 pm
I had some 'fun' figuring this out, this might be helpful for other Mac users to allow LibreDrive to work with the drive. I actually did it because the Region had not been set on the drive (It came with ZERO software) and some of the other software I was using was complaining that the region was not set. This killed 2 birds with one stone in that after the drive was flashed the LibreDrive functionality is available and the drive is now Region set as well (Region set to 'all')
I am on macOS Catalina 10.15.6 on a MacBook Pro 2020 and was able to successfully flash my MD-8107-U3 using titbits of info from this forum and elsewhere.
You can leave the files where you would like and not copy them as I did (Step 4) and not even change into the application direct (Step 5.) - it just means you will have to add the paths to where they are located for you in step 8.
Steps taken
1. download sdf.bin
2. download mk-firmware-pack-YYYYMMDD
- where YYYYMMD is the date of the latest firmware pack
3. Extract the file you need for your drive from mk-firmware-pack-YYYYMMDD -> In my case this was -> HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
4. then in terminal on the MacBook
- I then copied sdf.bin and the firmware file I extracted from the mk-firmware-pack-YYYYMMDD into my /tmp folder .
(this only to make sure both files in same place and nice easy path to type).
5. then in terminal change directory - > cd /Applications/MakeMKV.app/MacOS/Contents
6. type -> ls - al
you should see a directory listing and one of the objects in the listing is 'makemkvcon'
this step just confirms you are in the right directory
7. the type -> ./makemkvcon f -l
This will allow you to find your drive identifier, in my case -> ''/IOBDServices/D5D25996'
from the following output:
Found 1 drives(s)
00: /IOBDServices/D5D25996, /dev/rdisk3, /dev/rdisk3
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MOFK6283224
8. to actually perform the update, type -> ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
you will then be prompted to type in 'yes' to flash the firmware;
Reading input file /tmp/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MOFK6283224
yes
9. Once you type in yes and hit Enter - you should get the following output:
100% Operation finished
Done successfully
After hitting Enter the upload and flashing took about 20 seconds.
Hope this helps other Mac users!
Where do we download the sdf.bin — and the other package — from?
Cuddy2977
Post by Cuddy2977 » Tue Mar 28, 2023 7:27 pm
OK, I tried updating: and it didn’t do a dicky bird!
Post by Coopervid » Wed Mar 29, 2023 10:07 am
You have a Pioneer drive that doesn't need to be flashed! the mentioned procedure is only necessary for LG type drives. All you need to do is install the newest version of Makemkv 1.17.3 and to rip UHDs you have to allow internet access for Makemkv. That's it. Sdf.bin is part of the Makemkv package and internet access is needed a) to update sdf.bin b) to get the keys for UHD decrytion.
Cuddy2977
Post by Cuddy2977 » Wed Mar 29, 2023 5:41 pm
OK, I’ve retried: and managed to get a 4k DVD ripped.
Cheers!
