manuelrn
Post by manuelrn »
quietvoid wrote:
Sun May 01, 2022 1:38 pm
manuelrn wrote:
Sun May 01, 2022 1:36 pm
And in those cases, would it be possible for dovi_tool to omit those EOS/EOB NALUs and keep only the last one? (when muxing and injecting)
That is, if dovi_tool finds any EOS/EOB NALUs it checks if it is the last frame of the video, and if it is the last frame then dovi_tool keeps EOS/EOB NALUs but if it is not the last frame then it does not write that EOS/EOB NALUs.
No, it wouldn't be able to know how many frames there are.
I'd also rather not discard anything unnecessarily.
There's indeed a bug in 1.5.0 for files with multiple EOS NALUs present.
I'll add some tests and push the fix later.
Okay, you're right.
Just to make sure, that bug is already fixed in version 1.5.1, correct?
Thank you!
Godmax
Post by Godmax »
Is there a command with ffmpeg to add black bars to a cropped 4k Dolby Vision video file? Can be mkv or m2ts or ts doesnt matter.
aboulfad wrote:
Mon May 02, 2022 11:48 am
Found this 2019 comment from @reset_9999
the FEL and RPU test files can also be used to find out if your device uses the L5 active area metadata in the RPU. if it uses L5, there will be black bars otherwise it will be fullscreen.
I'm not aware of any HDMI device that uses L5 metadata the way the TV's internal player does.
I really don't understand how L5 works on HDMI devices. Seems they all ignore it and are not affected by the issue described here: viewtopic.php?p=121490#p121490
quietvoid
Post by quietvoid »
manuelrn wrote:
Mon May 02, 2022 11:59 am
Thank you!
Yes, see release notes: https://github.com/quietvoid/dovi_tool/ ... /tag/1.5.1
mux: Fixed repeating EOS NALUs by default. Fixes #146.
This only affected the default muxing options. If using --eos-before-el, the output file was correct.
aboulfad
Post by aboulfad »
RESET_9999 wrote:
Mon May 02, 2022 2:06 pm
I am terribly sorry, I realized now I may have mis quoted your comment in my above response. My thread of questions were all related to P7 converted to DV P5 dvdhe.5.06 BL+RPU and may have confused L5 with P5 ? I still have to read/learn about RPU metadata to understand the link above. Ah DV metadata levels !!!
I am just searching in posts to learn about the video test files you made and how to interpret them on my device chain. Merci ; - )
aboulfad
Post by aboulfad »
@nekno I re-created some DoVi mkv from my BD UHD and re-used the tools to create what I did a year ago. As you already know, yusesope tools convert P7 to P8 and mp4muxer slaps on a DoVi P5 header. It seems that is enough to fool Infuse to display DoVi so did my LG E7 internal player !!! So yeah "fake" or "frankenstein" DV P5 file for free.
As far as color space, RPU and all this stuff, I don't know what's happening. It's hard to compare with a movie without knowing the details of what is supposed to be. The test file was 10s so too short. Anyways its fun to learn all these tools (including dovi_tool), thanks to all : )
mtotheb
Post by mtotheb »
Have you guys ever come across a Profile 8 (dvhe 08.06) in an UHD Bluray? I thought only Profile 7 was used in these but the German Release of Lamb from Koch Media surprisingly is encoded like that.
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
quietvoid
Post by quietvoid »
mtotheb wrote:
Wed May 04, 2022 12:15 pm
I also think UHD BD is supposed to be profile 7 only.
do you have the BDinfo report of the disc ?
mtotheb
Post by mtotheb »
So in makemkv it says "HEVC Main10@L5.1 (dvhe.08.06 BL+RPU)" about the source.
The HEVC File is "Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible" ~ MediaInfo
But they even forgot to set the dvhe flag. I'm guessing that Bluray Players would just fallback to the HDR10 can't test it tho
I've also never seen a commercial uhd bluray being encoded with x265:
Writing library : x265 3.4+31-6722fce1f:[Mac OS X][clang 11.0.0][64 bit] 10bit
Encoding settings : cpuid=1049583 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / no-b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=1 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=60000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=80000 / vbv-bufsize=60000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1) / cll=420,69 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
mtotheb wrote:
Wed May 04, 2022 4:07 pm
it says that on the original M2TS file on the bluray disc?
the (A24 Exclusive) bluray is FEL DV:
Disc Size: 62,679,376,060 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 1:46:27.589 (h:m:s.ms)
Total Bitrate: 70.26 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 55879 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 7688 kbps (12.09%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
mtotheb
Post by mtotheb »
Yup that's straight off the Bluray. Great to know that the distributer here completely disregarded the FEL in probably the most unusal way for a bluray release
quietvoid
Post by quietvoid »
It should probably be compared to the FEL disc, in the hope that they're the same.
nekno
Post by nekno »
Found this site a while back claiming x264 compliance testing by Criterion, and Warner BD discs encoded with x264, so if true, I guess not a big surprise that x265 would be used in commercial UHD BDs.
More surprising might be doing the encoding on that Mac they had in the editing bay...
Mattl0
Post by Mattl0 »
mattmarsden wrote:
Mon Apr 25, 2022 12:57 pm
Mattl0 wrote:
Sat Apr 23, 2022 5:04 pm
Anyone tried the 5.0 fw from Ugoos on am6 b? Wonder how’s the dv playback. I will test it when I have time (currently the unit is somewhere, need to find it lol) .
F9220A1F-B95D-4B07-83FB-19CFD5159257.pngC8E9B873-8502-4BDF-B4FD-3602ACEBADDC.pngA594274E-B3FB-4A57-91F1-051FBD0A3621.jpeg
Do you know where I can download the firmware from?
Here you go https://mega.nz/folder/fo8yHCKa#BMc78ichXyiEB1OKyqA0lw
