Re: SDFtool Flasher
Post by MartyMcNuts » Sun May 01, 2022 11:15 pm
rayians wrote: Sun May 01, 2022 2:41 pm Another thing that is strange is I was attempting to go to firmware 1.00MK. I figured once 1.02MK was installed, all I had to do was another flash and it should work. I first tried without checking "ENC", it didn't work. I tried by checking ENC and it still didn't work. I feel like I am missing something here.
With these BP60NB10's with SVC: NB12, to downgrade to 1.00-MK firmware try the below steps.
1. Flash the drive with BP60NB10 1.02-MK.
2. Using the recovery option in SDFtool Flasher, select BP60NB10 1.02-MK as the incorrect firmware in the popup, then in the select firmware box, select BP60NB10 1.00-MK.
rayians
Re: SDFtool Flasher
Post by rayians » Wed May 04, 2022 8:57 pm
Marty, you are thebomb.com! Thank you so much!!
themoleculoman
Re: SDFtool Flasher
Post by themoleculoman » Sat May 28, 2022 7:02 am
Thank you so much Marty and other posters for the information. After reading through everything it only took 30 seconds to flash a newly bought WH16NS60 with OWC Pro enclosure :)
Error code showed up like other users mentioned, but MK1.03 was successfully flashed to MK1.02 and I'm ripping my first 4K UHD :)
TomKay
Re: SDFtool Flasher
Post by TomKay » Wed Jun 01, 2022 2:25 pm
Hello everyone,
I got an LG Hitachi - BH16NS55 and wanted to use the SDFtool Flasher (1st post) and the recommended firmware (HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936)
When selecting the device I will get an error window (https://prnt.sc/-ybXYwerJP6b) and an error message:
Running on W10 x64 and started it with empty/closed tray and admin rights:
https://prnt.sc/jjgaF2cw32Cs
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.FormatException: Input string was not in a correct format.
   at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
   at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
System.Private.CoreLib
    Assembly-Version: 6.0.0.0.
    Win32-Version: n/v.
    CodeBase: .
    Assembly-Version: 1.3.3.0.
    Win32-Version: n/v.
    CodeBase: .
System.Runtime
    Win32-Version: n/v.
    CodeBase: .
    Assembly-Version: 6.0.2.0.
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Drawing.Primitives
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Drawing.Common
    Win32-Version: n/v.
    CodeBase: .
System.Threading
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Collections
    Win32-Version: n/v.
    CodeBase: .
System.Diagnostics.Process
    Win32-Version: n/v.
    CodeBase: .
Microsoft.Win32.Primitives
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Threading.Thread
    Win32-Version: n/v.
    CodeBase: .
Accessibility
    Assembly-Version: 4.0.0.0.
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Numerics.Vectors
    Win32-Version: n/v.
    CodeBase: .
System.Memory
    Win32-Version: n/v.
    CodeBase: .
System.ComponentModel
    Win32-Version: n/v.
    CodeBase: .
System.Resources.Extensions
    Win32-Version: n/v.
    CodeBase: .
System.Drawing
    Win32-Version: n/v.
    CodeBase: .
System.ObjectModel
    Win32-Version: n/v.
    CodeBase: .
System.Linq
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Collections.Concurrent
    Win32-Version: n/v.
    CodeBase: .
mscorlib
    Win32-Version: n/v.
    CodeBase: .
Microsoft.Win32.SystemEvents
    Win32-Version: n/v.
    CodeBase: .
System.Collections.NonGeneric
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Private.Uri
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Xml.ReaderWriter
    Win32-Version: n/v.
    CodeBase: .
System.Private.Xml
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Net.WebClient
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Xml.XmlSerializer
    Win32-Version: n/v.
    CodeBase: .
Microsoft.Win32.Registry
    Win32-Version: n/v.
    CodeBase: .
System.Runtime.CompilerServices.Unsafe
    Win32-Version: n/v.
    CodeBase: .
System.Runtime.Loader
    Win32-Version: n/v.
    CodeBase: .
System.Windows.Forms.resources
    Win32-Version: n/v.
    CodeBase: .
System.Diagnostics.StackTrace
    Win32-Version: n/v.
    CodeBase: .
System.Reflection.Metadata
    Win32-Version: n/v.
    CodeBase: .
System.Collections.Immutable
    Win32-Version: n/v.
    CodeBase: .
************** JIT-Debuggen **************
Any idea on that? Can I just continue flashing or what did I do wrong?
TomKay
Re: SDFtool Flasher
Post by TomKay » Wed Jun 01, 2022 5:25 pm
Nevermind - I used dvdfab's feature to downgrade my drive. it worked :)
Re: SDFtool Flasher
Post by Coopervid » Wed Jun 01, 2022 8:12 pm
TomKay wrote: Wed Jun 01, 2022 5:25 pm Nevermind - I used dvdfab's feature to downgrade my drive. it worked :)
You should have first flashed to BH16NS55 1.0x and only then cross-flash it to BH16NS60. If you spent money for the DVDfab flasher you were too impatient.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Jun 01, 2022 10:45 pm
TomKay wrote: Wed Jun 01, 2022 2:25 pm Hello everyone,
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Runtime
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Threading
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Collections
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
Accessibility
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Memory
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Drawing
    Win32-Version: n/v.
    CodeBase: .
System.ObjectModel
    Win32-Version: n/v.
    CodeBase: .
System.Linq
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
mscorlib
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Private.Uri
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
System.Private.Xml
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
    Win32-Version: n/v.
    CodeBase: .
It looks like you are using a sata/USB adapter, which is causing the issue. (Notice the drive says Asmedia instead of BH16NS55)
TomKay
Re: SDFtool Flasher
Post by TomKay » Thu Jun 02, 2022 9:02 am
Coopervid wrote: Wed Jun 01, 2022 8:12 pm
Didnt buy it just because of this, had it before already, and just discovered it :)
papacarter
Re: SDFtool Flasher
Post by papacarter » Mon Jun 20, 2022 7:09 am
I have a ASUS BW-16D1HT connected to my laptop via usb / Sata, please see information about the drive here: (Screenshot 1)
Screenshot 1
Screenshot 1
screenshot 1 _ makemkv drive info.PNG (24.21 KiB) Viewed 20455 times
I see that the firmware isn't encrypted as per this screenshot obtained via the SDFtool (Screenshot 2)
Screenshot 2
Screenshot 2
screenshot 2 _ sdftool drive info.PNG (25.78 KiB) Viewed 20455 times
Although I tried flashing the drive using the ASUS flash tool, it was throwing "Updating Failure #5". Will the SDFTool be able to help?
I am keen to knwo how do I proceed?
Thanks in advance.
totofroto
Re: SDFtool Flasher
Post by totofroto » Mon Jun 20, 2022 3:12 pm
hallo
i am trying to flash my BR Drive, Model BH16NS55 with friendly Firmware,
which firmware for this drive
see the Pic that i have added
for Example i have selected MK version(see Pic)
is this correct, pls help meeee
edit:
as i understood i should do the following:
1- BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
2- WH16NS60 1.02MK > DE_LG_WH16NS60_1.00.bin
is that ok
Re: SDFtool Flasher
Post by Billycar11 » Mon Jun 20, 2022 10:15 pm
papacarter wrote: Mon Jun 20, 2022 7:09 am Hi,
I have a ASUS BW-16D1HT connected to my laptop via usb / Sata, please see information about the drive here: (Screenshot 1)screenshot 1 _ makemkv drive info.PNG
Thanks in advance.
It is encrypted use the command line flasher and use enc or download an old version of sdf GUI
It would also be helpful if you read the firmware and send it to Marty he could then add it to the list
papacarter
Re: SDFtool Flasher
Post by papacarter » Tue Jun 21, 2022 5:40 am
Thanks @Billycar11.
Could you please guide how do I use the command line flasher and which firmware version do I use? Apologies if this has been answered before as I am new to all this, what is "enc"?
I also have the read dump of the firmware and happy to send it to Marty.
Thanks in advance.
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jun 21, 2022 11:25 pm
Thanks in advance.
I'm not aware of any ASUS drives having encrypted firmware. Try flashing it to ASUS BW-16D1HT 3.10-MK using SDFTool flasher. It willl either flash successfully or it will not flash at all.
If the firmware is infact encrypted (I still doubt it) you can easily toggle the encrypted flag in SDFtool flasher by clicking on the red X.
papacarter
Re: SDFtool Flasher
Post by papacarter » Wed Jun 22, 2022 6:11 am
Hi Marty,
Legend ! Thanks for the suggestion and it worked like a charm :D
Truly appreciated!!
Thank You again 🙏
Re: SDFtool Flasher
Post by Billycar11 » Wed Jun 22, 2022 7:02 am
papacarter wrote: Wed Jun 22, 2022 6:11 am Hi Marty,
Truly appreciated!!
Thank You again
so was it encrypted did you click the x?
