Anyone have any suggestions for a good 4k UHD Blu-ray player?
isenki
#1 Post by isenki » Sat Apr 30, 2022 7:43 am
I'm looking for a 4k blu-ray player for my grandparents and need one that has no special frills and internet connections. I just want it to be exactly like a regular old DVD player: Pop in the disk, press play, and you're done. But I can't find one like that.. Any ideas?
Re: Anyone have any suggestions for a good 4k UHD Blu-ray player?
#2 Post by MartyMcNuts » Sat Apr 30, 2022 10:50 pm
isenki wrote: Sat Apr 30, 2022 7:43 am I'm looking for a 4k blu-ray player for my grandparents and need one that has no special frills and internet connections. I just want it to be exactly like a regular old DVD player: Pop in the disk, press play, and you're done. But I can't find one like that.. Any ideas?
As far as I am aware, all UHD players require internet access.
exitguy
#3 Post by exitguy » Sat Apr 30, 2022 11:37 pm
MartyMcNuts wrote: Sat Apr 30, 2022 10:50 pm As far as I am aware, all UHD players require internet access.
They have a connection but that does not mean you have to use it, except in the case if you want to do firmware upgrade but that can be done by downloading and using a USB stick.
If you want to use the inbuilt streaming apps, then yes - but if not just use it as a stand alone player connected to either a TV or AVR.
UHDRips
#4 Post by UHDRips » Sun May 01, 2022 12:52 am
Panasonic ub150 or Panasonic ub450 if they are available in your territory
#5 Post by MartyMcNuts » Sun May 01, 2022 12:57 am
exitguy wrote: Sat Apr 30, 2022 11:37 pm
Ok. Yep, after a bit more research an internet connection is only needed for firmware updates and if the disc has BD-Live features.
exitguy
#6 Post by exitguy » Sun May 01, 2022 9:47 am
Panasonic UB420 (non DV) or UB820 (with DV)
