Really dumb question about MakeMKV icons
MakOwner
#1 Post by MakOwner » Sat Apr 30, 2022 2:27 pm
I run MakeMKV in Linux (Thank you _everyone_ that makes this possible!!).
Edit: MakeMKV ver 1.16.7
I just updated to Mint 20.3 with a MATE desktop.
MakeMKV is all installed, registered and working fine - no complaints there.
But for the life of me I can't get any of the makemkv icons to work in either the menus or when I create a customer launcher on the tool bar.
Is there some setting I'm missing in MATE?
This worked in Mint 20.2 with a MATE desktop. It even worked after an upgrade to from 20.2 to 20.3.
I just did a fresh install because this desktop had been upgraded since 20.0 and it was time after installing and removing some java based applications.
This is the list of icons installed from MakeMKV under /usr/share/icons
I have tried every one of them.
./hicolor/256x256/apps/makemkv.png
./hicolor/32x32/apps/makemkv.png
./hicolor/16x16/apps/makemkv.png
./hicolor/22x22/apps/makemkv.png
./hicolor/128x128/apps/makemkv.png
./hicolor/64x64/apps/makemkv.png
MakOwner
Re: Really dumb question about MakeMKV icons
#2 Post by MakOwner » Sat Apr 30, 2022 2:33 pm
Replying to my own post, but while I have not _solved_ this, I do have a work around.
I mounted the drive from my previous install and copied the icon from the hicolor/128x128/app directory over to the new icons folder, and it works.
Maybe the icons from the 1.16.7 install are corrupted?
Dunno.
