Edit: MakeMKV ver 1.16.7
I just updated to Mint 20.3 with a MATE desktop.
MakeMKV is all installed, registered and working fine - no complaints there.
But for the life of me I can't get any of the makemkv icons to work in either the menus or when I create a customer launcher on the tool bar.
Is there some setting I'm missing in MATE?
This worked in Mint 20.2 with a MATE desktop. It even worked after an upgrade to from 20.2 to 20.3.
I just did a fresh install because this desktop had been upgraded since 20.0 and it was time after installing and removing some java based applications.
This is the list of icons installed from MakeMKV under /usr/share/icons
I have tried every one of them.
./hicolor/256x256/apps/makemkv.png
./hicolor/32x32/apps/makemkv.png
./hicolor/16x16/apps/makemkv.png
./hicolor/22x22/apps/makemkv.png
./hicolor/128x128/apps/makemkv.png
./hicolor/64x64/apps/makemkv.png
