Errors on Opening Disk
cranks
Post by cranks »
Tried to rip Aquaman 4k Ultra HD disk using my HL-DT-ST BD-RE BU40N on firmware 1.0 but got the below errors when opening the disk.
After an hour or so I cancelled the operation.
What's the cause of this??
MakeMKV v1.16.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Using Java runtime from C:\Program Files\Common Files\Oracle\Java\javapath\java.exe
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO4L91B5327' at offset '3014656'
Error 'Internal error - Operation was cancelled (135)' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO4L91B5327' at offset '3014656'
Title #00002.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Internal error - Operation was cancelled (135)' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
Title #00009.mpls was skipped
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Internal error - Operation was cancelled (135)' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '0'
Title #00089.mpls was skipped
Title #00093.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls was skipped
Title #00042.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.mpls was skipped
Title #00156.mpls was skipped
Title #00157.mpls was skipped
Title #00158.mpls was skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts was skipped
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts was skipped
Title #00059.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
bmillham
Re: Errors on Opening Disk
Post by bmillham »
Dirty disc. Clean it.
cranks
Post by cranks »
Huh...is that it? I'll try that thanks!
