Uncharted 2022 2022
coffee70
Uncharted 2022 2022
#1 Post by coffee70 » Fri Apr 29, 2022 6:01 pm
vol key needed for
Uncharted 2022 uk uhd
ictbydesign
Re: Uncharted 2022 2022
#2 Post by ictbydesign » Sat Apr 30, 2022 9:15 am
I emailed it to Mike yesterday.
coffee70
#3 Post by coffee70 » Sat Apr 30, 2022 1:37 pm
ok many thanks
ictbydesign
#4 Post by ictbydesign » Sun May 01, 2022 8:51 am
You should be able to rip this now.
aboulfad
#5 Post by aboulfad » Tue May 10, 2022 10:08 pm
It seems there's another version (US/CAN?) which I still can't decrypt, I emailed the AACS dump to svq@makemkv.com: MKB20_v76_Uncharted_8FB2.tgz
makemkvcon info disc:0
MakeMKV v1.16.7 linux(armel-release) started
Debug logging enabled, log will be saved as file:///home/pi/MakeMKV_log.txt
DEBUG: Code 0 at Y+~RLT\ $:S[=ynaXj[FO@:29393631
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as file:///home/pi/.MakeMKV/MKB20_v76_Uncharted_8FB2.tgz
DEBUG: Code 0 at 86{:TJQ\Mp&(sB6G:29396092
DEBUG: Code 0 at 86{:TJQ\Mp&(sB6G:29395172
Total 0 titles
luv2fly3
#6 Post by luv2fly3 » Wed May 11, 2022 12:41 am
I also found my UHD version won't open. I just emailed the dump as well.
aboulfad
#7 Post by aboulfad » Thu May 12, 2022 11:06 am
It works now for my version, thank you :)
RebootedReality
#8 Post by RebootedReality » Sun May 22, 2022 8:42 pm
Emailed mine as well. Uncharted 4K Ultra–HD MKB20_v76_Uncharted_1AB8.tgz
samcomeau
#9 Post by samcomeau » Sat May 28, 2022 3:49 am
Just sent mine CAN (Québec version) Uncharted BD
MKB_v76_Uncharted_47B2.tgz
albain
#10 Post by albain » Mon Jun 27, 2022 2:44 pm
Same here with my european/french disk
Thank you
#11 Post by Woodstock » Mon Jun 27, 2022 4:21 pm
It is best to send the file to svq@makemkv.com, and just report the file name here.
