vol key needed for
Uncharted 2022 uk uhd
Uncharted 2022 2022
coffee70
Uncharted 2022 2022
ictbydesign
Re: Uncharted 2022 2022
I emailed it to Mike yesterday.
ictbydesign
You should be able to rip this now.
aboulfad
It seems there's another version (US/CAN?) which I still can't decrypt, I emailed the AACS dump to svq@makemkv.com: MKB20_v76_Uncharted_8FB2.tgz
makemkvcon info disc:0
MakeMKV v1.16.7 linux(armel-release) started
Debug logging enabled, log will be saved as file:///home/pi/MakeMKV_log.txt
DEBUG: Code 0 at Y+~RLT\ $:S[=ynaXj[FO@:29393631
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as file:///home/pi/.MakeMKV/MKB20_v76_Uncharted_8FB2.tgz
DEBUG: Code 0 at 86{:TJQ\Mp&(sB6G:29396092
DEBUG: Code 0 at 86{:TJQ\Mp&(sB6G:29395172
Total 0 titles
luv2fly3
I also found my UHD version won't open. I just emailed the dump as well.
aboulfad
It works now for my version, thank you
RebootedReality
Emailed mine as well. Uncharted 4K Ultra–HD MKB20_v76_Uncharted_1AB8.tgz
samcomeau
Just sent mine CAN (Québec version) Uncharted BD
MKB_v76_Uncharted_47B2.tgz
albain
Same here with my european/french disk
Thank you
Thank you
It is best to send the file to svq@makemkv.com, and just report the file name here.
