af2kk
Post
by af2kk »
Hi there,
Support for the Pioneer BDR-XD07 would be much appreciated.
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: XXXXXXXXXXX
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 57
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8D30
Firmware version: GENE
dump_FW_XXXXXXXXXXX.tgz has been saved.
Cheers,
af2k
Matek234
Post
by Matek234 »
Same here.
Is this supported?
It works with DVD but when I insert UHD Blu-ray disc it just says No disc inserted
OS device name: /dev/sr0
Revision: 1.03
Serial number: AGDL008034WL
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
Post
by Coopervid »
af2kk - you should upgrade to firmware 1.03.
To both of you: Only drives that contain an "U" in their names support UHDs. Others don't.
