Re: SDFtool Flasher
Hi everyone,
First, thank you for your hard, great work.
Also, apologies for my total newbie-ness and my less-than-bright English.
I'm trying to flash my Asus BW-16D1HT drive, using the SDFTool Flasher GUI, and I have a few questions before I even click "Start":
a) It looks like the installed firmware version for the drive is 3.10. Should I assume it is an appropriate version to start flashing?
b) If yes, and if I understand well, I should patch that firmware to 3.10MK, shouldn't I? That is, selecting "WRITE firmware" and the right MK firmware, then click "START"?
c) From the GUI, the firmware doesn't seem to be encrypted. Should I keep it that way?
Any hint would be greatly appreciated!
Re: SDFtool Flasher
a) The most important thing is that the Makemkv GUI status shows drive platform M1959. I assume it is as you have firmware 3.10 on it.
b) Yes
c) ASUS firmware is not encrypted. All newer LG firmwares are. "Enc" should be left unchecked therefore.
b) Yes
Re: SDFtool Flasher
Yes. Sorry about the typo.Franchiver wrote: ↑Tue Apr 26, 2022 3:16 pmThank you for the quick answer!
I guess you mean "MT1959", don't you?
Re: SDFtool Flasher
Never mind. Thank you a lot for the help! My very first UHD r*p worked like a charm!
Re: SDFtool Flasher
Hi Everyone,
I recently purchased an LG BP60NB10 which came from factory with 1.02 firmware. It actually would read UHD discs but I was getting an "error while reading" message when using DVDFab. I figured it needed to be flashed. I have previously flashed a WH16NS40 that came from factor with 1.05 and had no issues. I used the flasher tool (v1.2.0) but something tells me the flash didn't work. After the flash, the description of the firmware in "Please select a drive" didn't change. It still says "K - HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIM03LC991356" and the MK firmware is "HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935". Additionally, I am still getting the "error while reading" message in DVDFab on every disc and they are in nearly flawless condition. I did select "WRITE" and "ENC" when I tried the flash. I am not sure what to try next. Any advice would be greatly appreciated. Thank you!!
Re: SDFtool Flasher
Umm I don't know the bp60 firmware that's works with dvdfab there might not be any you may need to flash to BU40N 1.00rayians wrote: ↑Sun May 01, 2022 2:10 pmHi Everyone,
And if that's a nb12 drive you might have some issues
Re: SDFtool Flasher
Billy, does it seem to you that the flash was successful? Should the description of the firmware have changed?
Re: SDFtool Flasher
Would need to see the makemkv drive info section
Re: SDFtool Flasher
OS device name: K:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03LC991356
Firmware date: 2120-05-07 09:35
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: INDEPENDENCE_DAY_RESURGENCE
Timestamp: 2016-08-30 15:53:17
Protection: AACS2.0/C v61
Data capacity: 53.96 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
OS device name: K:
Revision: 1.02
Disc Information
Number of layers: 2
Re: SDFtool Flasher
Another thing that is strange is I was attempting to go to firmware 1.00MK. I figured once 1.02MK was installed, all I had to do was another flash and it should work. I first tried without checking "ENC", it didn't work. I tried by checking ENC and it still didn't work. I feel like I am missing something here.
Re: SDFtool Flasher
Yeah it's flash and will work with makemkv yeah the not flashing to nb 10 firmware is a nb 12 follow mine or Marty's sequence for nb52 stuff but do it with nb 12 stuff basically check recovery or refresh the current one with bootloader and from then on you can flash whatever you want.rayians wrote: ↑Sun May 01, 2022 2:41 pmAnother thing that is strange is I was attempting to go to firmware 1.00MK. I figured once 1.02MK was installed, all I had to do was another flash and it should work. I first tried without checking "ENC", it didn't work. I tried by checking ENC and it still didn't work. I feel like I am missing something here.
Re: SDFtool Flasher
Is there another location to download the latest SDFtool Flasher? I downloaded the one from page 1 of this posting and it looks crunched and is impossible to read. I even tried changing my display settings and it didn't do anything for the flasher.
Re: SDFtool Flasher
Thank you, d00zah, that did it!
