unable to save mkv of The A-Team
corvin
#1 Post by corvin » Mon Mar 14, 2011 7:56 am
report as below, any ideas?
Saving 1 titles into directory /Volumes/media-2/Blu-Ray Movies/The_A-Team
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00331.m2ts' at offset '5111808'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00331.m2ts' at offset '9830400'
Failed to save title 1 to file /Volumes/media-2/Blu-Ray Movies/The_A-Team/title01.mkv
0 titles saved, 1 failed
Re: unable to save mkv of The A-Team
#2 Post by mike admin » Mon Mar 14, 2011 8:22 am
corvin wrote:report as below, any ideas?
Looks like physically damaged disc. Please try making full disc backup and see if any errors show up.
corvin
#3 Post by corvin » Tue Mar 15, 2011 11:55 am
back-up works fine
Backing up disc into folder "/Volumes/media-1/Blu-Ray Movies/backup/A_TEAM_F3"
Backup done
#4 Post by mike admin » Wed Mar 16, 2011 7:39 am
corvin wrote:back-up works fine
Backup done
Then you should be able to open a backup copy with MakeMKV ( Select File menu, then Open ) and convert from there. Looks like you had a glitch reading the file.
corvin
#5 Post by corvin » Wed Mar 16, 2011 8:31 am
Ok thankls that seemed to work.
I did try converting from disk about 5 times???
I did see a number of currupt entries though, i have posted them below if you are interested in brousing them. Sorry i'm not sure if i could have just added them as an attechment :|
Opening files on harddrive at /Volumes/media-2/Blu-Ray Movies/backup/A_TEAM_F3/
Downloading latest SVQ(s) to /Volumes/media-1/Blu-Ray Movies ...
Loaded 14 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed, got 1 FUT(s) for 57 clip(s)
File 00381.mpls was added as title #0
File 00801.mpls was added as title #1
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00802.mpls was added as title #2
Title #00020.mpls has length of 110 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
File 00800.mpls was added as title #3
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title #00890.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00377.m2ts has length of 91 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00303.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00357.m2ts has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00387.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00394.m2ts has length of 99 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00309.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00335.m2ts has length of 51 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00316.m2ts has length of 120 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00333.m2ts has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00328.m2ts has length of 80 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00891.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00350.m2ts has length of 367 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00347.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00379.m2ts has length of 439 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00334.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00355.m2ts has length of 114 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00319.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00390.m2ts has length of 72 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00338.m2ts has length of 475 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00327.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00358.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00359.m2ts has length of 248 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00360.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00311.m2ts has length of 115 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00345.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00393.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00356.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00336.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00378.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00324.m2ts has length of 329 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00388.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00380.m2ts has length of 96 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00301.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00342.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00386.m2ts has length of 301 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00306.m2ts has length of 200 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00313.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00352.m2ts has length of 74 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00383.m2ts has length of 198 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00385.m2ts has length of 275 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00321.m2ts has length of 293 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00353.m2ts has length of 58 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00889.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00392.m2ts has length of 100 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00384.m2ts has length of 246 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00391.m2ts has length of 108 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00389.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00331.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00354.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/media-1/Blu-Ray Movies/The_A-Team
The source file '/BDMV/STREAM/00341.m2ts' is corrupt or invalid at offset 549322752, attempting to work around
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
1 titles saved
#6 Post by mike admin » Thu Mar 17, 2011 8:47 am
Hi. Please go to MakeMKV preferences, select "BD+" tab, make sure that "BD+ directory" is set and enable "always save BD+ dump". Then open this disc again, and send produced BD+ dump file to support@makemkv.com .
Thanks.
corvin wrote:Ok thankls that seemed to work.
1 titles saved
setarip_old
#7 Post by setarip_old » Fri Mar 18, 2011 1:42 am
" A_TEAM_F3 " is indicative of a torrent download, which cannot be discussed at the MakeMKV Forums...
corvin
#8 Post by corvin » Fri Mar 18, 2011 12:41 pm
Hi Mike,
Below is the dump, however this time the mkv worked??? I had tried it many times prior, the only difference i know of is the dump file and i saved it to an alternate drive as the 1st one was full.
Oh and setarip_old u r wrong!!!
dump_The_A-Team_3A01E1251AE79C4F.tgz
reebok
#9 Post by reebok » Fri May 27, 2011 6:22 pm
I am having virtually the exact same problem with this movie. I'm not getting the corrupt errors like the original poster, but I am getting problems such as Error 'Scsi error - MEDIUM ERROR:1090'. maybe it's a bad disc, but it seemed odd we have the same problem.
reebok
#10 Post by reebok » Fri May 27, 2011 6:30 pm
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00311.m2ts' at offset '407562240'
#11 Post by mike admin » Sat May 28, 2011 12:10 pm
reebok wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00311.m2ts' at offset '407562240'
This is physical disc error.
reebok
#12 Post by reebok » Sat May 28, 2011 1:36 pm
is there a way to force skip a certain track? it fails on 00311.m2ts every time, which is only 1min 55sec long according to bdinfo. I would rather just rip it without it if I can. thanks.
nobix
#13 Post by nobix » Sun Jun 05, 2011 1:41 am
reebok wrote:is there a way to force skip a certain track? it fails on 00311.m2ts every time, which is only 1min 55sec long according to bdinfo. I would rather just rip it without it if I can. thanks.
Some of my blu-ray discs have physical damage. I am okay to lose a couple of seconds video data in a track. Not sure if makeMKV can ignore the disc error to continue.
#14 Post by mike admin » Sun Jun 05, 2011 12:45 pm
nobix wrote:Some of my blu-ray discs have physical damage. I am okay to lose a couple of seconds video data in a track. Not sure if makeMKV can ignore the disc error to continue.
It will try to do so, but if too much data is damaged then it will ultimately fail.
marky9074
#15 Post by marky9074 » Mon Apr 04, 2016 11:51 am
Sorry to resurrect this thread. I'm getting the same with the A-Team (only played once - no damage). When doing a full disc backup I get the following:
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00338.m2ts' at offset '1429039104'
