Dawn of The Planet of the Apes & Dune won't rip
blessedbasil
Post by blessedbasil » Fri Apr 22, 2022 4:28 am
I get the following error when ripping the Bluray disc for Dawn of the Planet of the Apes:
MakeMKV v1.16.7 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0A863D82546DB8453826039C672F0257698 to device 'SG:dev_21:2'
It's odd because it looks like other people on the forum have been able to rip this.
Same issue with Dune.
My logs are attached. I'm running on Linux with MakeMKV v1.16.7.
MKB_v68_Dune_BF5A.tgz
(144.63 KiB) Downloaded 246 times
MKB_v47_Dawn_of_the_Planet_of_the_Apes_723A.tgz
(157.76 KiB) Downloaded 234 times
Re: Dawn of The Planet of the Apes & Dune won't rip
Post by Billycar11 » Fri Apr 22, 2022 1:06 pm
What's your drives aacs version
blessedbasil
Post by blessedbasil » Fri Apr 22, 2022 3:02 pm
Internal Drive
OS device name: /dev/sr0
Manufacturer: PLDS
Product: BD-RE DH-4B1S
Revision: 7D13
Serial number: 0000061775
Highest AACS version: 75
Disc Information
Label: Dawn of the Planet of the Apes
Timestamp: 2014-09-23 14:28:39
Protection: AACS v47, BD+ v2014.9
Data capacity: 43.45 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
External Drive
OS device name: /dev/sr2
Product: BD-RE BU10N
Revision: GS01
Serial number: M6CE4FK0908
Firmware date: 2113-05-02 09:21
Bus encryption flags: 1F
Firmware version: 0.GS01V
Disc Information
Disc is being loaded (never loads)
blessedbasil
Post by blessedbasil » Fri Apr 22, 2022 3:13 pm
Ezatoka
Post by Ezatoka » Fri Apr 22, 2022 5:17 pm
I always thought LibreDrive circumvents that problem with the AACS version
guitar185
Post by guitar185 » Thu Apr 28, 2022 2:13 am
I am having an issue with the Dune 4k disc as well, getting the following output when trying to open. Using the latest version of MakeMKV
OUTPUT:
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29396092
DEBUG: Code 0 at EVz_tTp6BRfYN?zX:29395172
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Downloading latest HK to C:\Users\jkepl/.MakeMKV ...
DEBUG: Code 2400288796 at 5BX&Q]n@$={`'k.:29393999
DEBUG: Code 0 at vY-GuZ@?5^tcx_N8:121267362
Saved AACS dump file as C:\Users\..../.MakeMKV/MKB20_v76_Dune_4C7F.tgz
INFO
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: KLLL26E2423
Firmware date: 2117-04-25 17:56
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: DUNE
Timestamp: 2021-10-25 15:48:03
Protection: AACS2.0/C v76
Data capacity: 90.66 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Post by Woodstock » Thu Apr 28, 2022 3:22 am
Depending on when you did this, the exchange of data between MakeMKV and the server didn't happen. Try it again now that the server connection should work.
blessedbasil
Post by blessedbasil » Thu Apr 28, 2022 5:17 pm
I tried again, making sure I have internet access enabled, but I got the same error. Debug log attached.
MakeMKV_log.txt
(22.85 KiB) Downloaded 249 times
Post by dcoke22 » Thu Apr 28, 2022 5:54 pm
Debug log started at Thu Apr 28 16:46:54 2022 , written by MakeMKV v1.16.7 linux(x64-release)
001005:0000 MakeMKV v1.16.7 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/plex-user/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.68.0/OpenSSL/1.1.1f/1.40.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at LV2@6_ V6|/MwT2u-GhPKt:29393631
SDF  v08a: HL-DT-ST_BD-RE_BU10N_GS01_211305020921_M6CE4FK0908
No  SDF v08a: HL-DT-ST_DVD-RAM_GH40L_1.03_20081127123456_903CC003595
SDF id v08a: HL-DT-ST_DVD-RAM_GH40L_1.03_20081127123456_903CC003595
No  SDF v08a: PLDS_BD-RE_DH-4B1S_7D13___0000061775
No auto SDF v08a: PLDS_BD-RE_DH-4B1S_7D13___0000061775
DEBUG: Code 0 at bkX.<}Qz %8ITV6_\:121264142
DEBUG: Code 0 at V+xT(ebZo^o3&}Y6:213136769
SDF id v08a: PLDS_BD-RE_DH-4B1S_7D13___0000061775
DEBUG: Code 2147483648 at er;N^34P}czbz%/7:121264625
DAFD=PAAAADAAAAEABDQEEAAADAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..045699347E2B3C5C6EAC3BCE8652D9607A9 to device 'SG:dev_21:2'
001003:0020 DEBUG: Code 0 at Bg~(Z`_>-pVCj*aX`:213130766
001003:0020 DEBUG: Code 0 at G:l9+v#"}dm.*cre<U:121263429
001003:0020 DEBUG: Code 0 at G:l9+v#"}dm.*cre<U:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200744100720..0F3E656F6A1EAD9D4855310584C703BA4A7 to device 'SG:dev_21:2'
001003:0020 DEBUG: Code 1 at G:l9+v#"}dm.*cre<U:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002440 to device 'SG:dev_21:2'
DEBUG: Code 0 at Bg~(Z`_>-pVCj*aX`:213130306
001003:0020 DEBUG: Code 0 at G:l9+v#"}dm.*cre<U:121264395
001003:0020 DEBUG: Code 4 at G:l9+v#"}dm.*cre<U:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003332:0000 Saved AACS dump file as file:///home/plex-user/.MakeMKV/MKB_v47_Dawn_of_the_Planet_of_the_Apes_723A.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at Vm_V6jzi1sgq}qU5:29396092
001003:0020 DEBUG: Code 0 at Vm_V6jzi1sgq}qU5:29395172
At least the network seemed to work this time. The disc might be dirty. Giving it a gentle cleaning might help.
guitar185
Post by guitar185 » Sat Apr 30, 2022 2:00 am
So to close out my issue, I have a Unifi based network backbone, which was geo filtering/blocking the HK downloads, once I brought that security system offline while I ran MakeMKV, the HK download succeeded and I was able to get Dune to rip successfully. Cheers!
